Latest: flipflap
Overall: 17140
Online Now [133]:
Visitors: 132
Today: 28178
Total: 113775521
Forums › The Car › 206 Problems › 206 1.4 reverse light bulb
Corsa_Alex
PostPosted: Fri Dec 31, 2010 6:30 am Up
hi, my gf has got a 04 plate 206 that she bought about a month ago and the reverse light bulb didnt work. just wondering what bulb you need for it and if anyone got a link to one on ebay or something for a cheap one? and briefly how do you change the bulb on these cars? open boot, take out back of light and replace like normal ? cheesr
Smile
mjsroofing
PostPosted: Fri Dec 31, 2010 6:35 am Up
pick one up when you fill up at garage, take old one and match it up with new.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Fri Dec 31, 2010 6:36 am Up
Clear BU 382 bulb.
You can pick these up anywhere.
Halfords
Petrol stations
Supermarkets
Corsa_Alex
PostPosted: Fri Dec 31, 2010 6:45 am Up
oh okay cheers guys so one like this then? cgi.ebay.co.uk/382-Cle...1746wt_905
what about fitting it? open boot and take out the back from inside the boot then?
Smile
PostPosted: Fri Dec 31, 2010 6:50 am Up
One little plastic wing nut to undo, be warned they can be tight!
Adjustable spanner / mole grips on standby just in case.
Yes that the correct bulb.
Corsa_Alex
PostPosted: Fri Dec 31, 2010 7:00 am Up
cheers mate
Smile
Corsa_Alex
PostPosted: Tue Jan 04, 2011 2:37 pm Up
oh and just another quick thing, which side is the reverse light in? the left or right rear light? or both??
Smile
PostPosted: Tue Jan 04, 2011 2:51 pm Up
Both
PostPosted: Wed Jan 05, 2011 5:18 am Up
Awaits the " there still not working thread " Laughing
PostPosted: Wed Jan 05, 2011 8:30 am Up
Only looked at the last post Laughing
The bulb is the same as whats in the indicators and rear fog light, so you can take that out and fit it to see if they work. But if both reverse lights aren't working, then it sounds more likely that its the fuse or switch at fault.
Corsa_Alex
PostPosted: Wed Jan 05, 2011 12:25 pm Up
well the two bulbs have arrived today so maybe fitting them for her tomorrow and will see if that fixes them if not where is the fuse boards on these cars and which fuse do you know?
Smile
