Forums › The Car › 206 Problems › 2001 GTI misfire |
Posted: Tue Dec 28, 2010 12:10 pm |
Hi
Wondered if anyone has any advice- I have changed plugs, oil and fuel filters.
Car originally started mis- firing and 'chugging' from cold start 1st thing 1 morning. Engine management light came on and engine cut out- re-started but no change- as a result changed the crank sensor and for a couple of months all seemed OK.
However have had a couple of instances where symptoms have returned, but not so extreme- mis-firing from cold- car really shakes, but after 5 mins max it stops and is OK for the rest of the day- even if left for several hours, but Xmas morning it came back with a vengeance and again after 5 mins max all seemed ok, but this time the engine management light stayed on until today- it went off after I started the car to come home from work.
Has anyone any ideas?
Cheers
however today th e engine
Have now noticed that car seems to have slight rough idle- all the above seems to happen when car is on auto choke
Posted: Wed Dec 29, 2010 3:17 pm |
clean out the injectors?
Posted: Wed Dec 29, 2010 3:25 pm |
Cars haven't had chokes for nearly 20 years. So it only does it from cold? Is it worse when the weather is colder?
Posted: Fri Dec 31, 2010 2:51 pm |
Hi
yes it is worse when the weather is colder,when i start car up from cold is the only time it happens.Would you recommend injector cleaner.
Thanks for the replys
Posted: Fri Dec 31, 2010 4:33 pm |
Same thing happened with my 2001 GTi 138. I changed the coilpack as recommend and all was well afterwards
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Sat Jan 01, 2011 4:57 am |
Mine did the same thing always spluttered fir about 100 yards then ran fine. Was worse in colkd weather. Mine happened as soon as I fitted the Longman head. The fix in the end was to fit some new hydraulic lifters.
