Latest: DanDan17
Overall: 17128
Online Now [57]:
Visitors: 56
Today: 5193
Total: 100565931
Forums › The Car › 206 Problems › 206 gti 180 misfirng and searching
Go to page Previous  1, 2
NICKST
PostPosted: Fri Dec 31, 2010 7:38 am Up
It's not vvt sensor that's near the coil pack.
kieron
PostPosted: Fri Dec 31, 2010 8:51 am Up
it is the only sensor near the coil pack
Account suspended
mjsroofing
PostPosted: Fri Dec 31, 2010 8:55 am Up
is that not the lamdba sensor
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
kieron
PostPosted: Fri Dec 31, 2010 8:57 am Up
its not the arrow pointed its at the end of the coil pack
thats a pic i borrowed of another post
Account suspended
mjsroofing
PostPosted: Fri Dec 31, 2010 9:01 am Up
ar right sorry...........
Mark
PostPosted: Fri Dec 31, 2010 9:46 am Up
The thing next to the coil pack is the VVT solenoid. That controls the oil pressure to the inlet cam pulley.
danjames
PostPosted: Fri Dec 31, 2010 9:27 pm Up
cheers for all the advice people gona get the correct tools and time it properly, my freind works for arnold clarke so cany get the correct tools from there and do it properly
blue gti 180, anthrecite wheels, lowered 60mm, debadged bonnet, debadeged grill, morettes hid in headlights an fogs, full sp pack, WANTED CAT CAMS NOWWWW
NICKST
PostPosted: Sat Jan 01, 2011 5:26 am Up
Didn't say it's near the coilpack I said it's near the tb. And you can see it threw the inlet manifold near the throttle body it's black with a connector going to it and held in by a 9mm bolt I think. I did say it's not the vvti sensor because that's near the coil pack.
PostPosted: Sat Jan 01, 2011 5:28 am Up
Im shocked an Arnold Clark dealer would have the tools to do this.
Shocked
danjames
PostPosted: Sat Jan 01, 2011 10:54 am Up
searching has stopped it was down to flat battery and me not having fitted the alternator yet but still have a missfire, going to try the coil tomorrow
danjames
PostPosted: Mon Jan 10, 2011 3:05 pm Up
misfire ended up being injector number 3 wasnt spraying. swapped it with another injector to see if the injector was at fault and they all started spraying lmao all that hassle for somthing so small lol
gti180boy
PostPosted: Thu Jan 13, 2011 4:03 pm Up
kieron206gti wrote:
ive never done a 180 cambelt but my brother has done loads at work and it still takes him 4 hours or so
Come on kieron 4 hours really i can do it in 2hours if needed to but on average 3 hours as i like to torque up every thing Smile
I can have the old cambelt in my hand in 40mins ish Wink
Kyle
180 Doctor
Page 2 of 2
