Latest: DanDan17
Overall: 17128
Online Now [67]:
Visitors: 66
Today: 40396
Total: 100468057
Forums › The Car › 206 Problems › 206 Knocking with new wheels?
Kermit21
PostPosted: Sat Jan 01, 2011 1:47 pm Up
I have recently fitted some 15", 4 stud multi fit alloy wheels to my pug.
they have large tyres on (2") making the total wheel 17".
I managed to get the wheels to fit my car, eventually.
However, my brakes don't feel as good as before,
and there is a clonking, or knocking noise coming from the front??
Jay
PostPosted: Sat Jan 01, 2011 1:49 pm Up
Are you using the correct alloy wheel bolts for these wheels?
Are the centre bore holes to large for Pug fitment?
Kermit21
PostPosted: Sat Jan 01, 2011 1:52 pm Up
I bought some plastic "hubcentric" spacers to make sure that the wheel all fits correctly.
However, i'm just using the standard wheel nuts but was told as long as i got 6 turns of thread they'd be fine?
Jay
PostPosted: Sat Jan 01, 2011 1:55 pm Up
Do the wheels take a flat seat OR taper wheel bolt?
Kermit21
PostPosted: Sat Jan 01, 2011 1:57 pm Up
When i asked about this, i was told that i should "probably" use a taper.
Recon this could be my problem?
Jay
PostPosted: Sat Jan 01, 2011 1:59 pm Up
You need to use the correct type of bolts for the wheels fitted.
You need alloy wheel bolts with the correct type seat for the wheels you have fitted.
They will either be tapered OR they will have a flat washer.
Using the wrong bolts in worse cases = loosing a wheel as your driving along which isnt a good thing Wink
Kermit21
PostPosted: Sat Jan 01, 2011 2:00 pm Up
yeahh its probalby not!
so hopefully, using the "correct" bolts, should stop my knocking??
Jay
PostPosted: Sat Jan 01, 2011 2:01 pm Up
Well its a good place to start Laughing
Kermit21
cheers buddy!
Jay
meady
PostPosted: Sat Jan 01, 2011 2:22 pm Up
Trade Rating: +45
and even if it dont stop the knockin g it will greatly reduce the chance of your wheel rolling past you as your driving along the motorway
TEAM - I HATE FACEBOOK Smile
