Latest: DanDan17
Overall: 17128
Online Now [194]:
Visitors: 193
Today: 15456
Total: 100615875
Forums › The Car › 206 Problems › Brake Bias
Brake Bias
NXT206
PostPosted: Mon Jan 03, 2011 8:20 pm Up
Just need some info on the above topic. I've gone through 4 sets of rear pads(disk)and still on the first set on the front and they still have plenty of meat on them. The problem is the front's squeal when braking. The car has done 85,000kms. My question is: can you put more bias on the front pads?
Regards,
The Pug from downunder
PostPosted: Mon Jan 03, 2011 9:40 pm Up
you better check you rear brake is not stuck first.
this is not normal.
or do you use use handbrake to brake lol
PostPosted: Tue Jan 04, 2011 3:33 am Up
You need to have the braking system checked over as something isnt right with it.
What age of 206?
Does it have ABS fitted?
Does it have a brake compensator valve on the rear axle ( early cars will, even some fitted with ABS! )
