Latest: S2cgm
Overall: 17178
Online Now [7542]:
Visitors: 7541
Today: 68607
Total: 135963762
Forums › The Car › 206 Problems › key won"t start the car...!!
toto
PostPosted: Tue Jan 04, 2011 4:03 pm Up
My car won't start with my 2 plip key.It opens the doors,but it won"t start.I have a spare one ,but how do I fix the plip one.I tryed www.programyourkeys.com but it doesn"t work.I have a key code,but don't know what to do with it.My car it's 1.4 hdi.please I need advice
be who you are and say what you feel.for those who mind it wouldn\"t matter.for those who matter,it wouldn\"t mind
Geoff
PostPosted: Tue Jan 04, 2011 4:05 pm Up
Did they key ever work?
toto
PostPosted: Tue Jan 04, 2011 4:56 pm Up
I bought the car last week,I think it worked then.But I changed the batery.Does that have something to do with the key not working
PostPosted: Tue Jan 04, 2011 5:00 pm Up
What year is the 206?
'51 plate or newer, did you disconnect the battery right?
Does the spare one work ok?
M60SHW
is the battery the right one/ right way round lol and does the "blip" key start the car or just tern it over?
"edit" car battery or key battery lol
Team, ST
Team, Gti 138 track slag
toto
PostPosted: Tue Jan 04, 2011 5:12 pm Up
The other key works fine,the battery is "right" one as well.I've changed the key battery as well.The car is 51 plate,2002.They just quote me 70J to program it.Damn
MNARAA
PostPosted: Tue Jan 04, 2011 5:30 pm Up
Did any small pointless looking bits of plastic fall out when you changed the battery? If so that'd be the transponder chip that disables the immobiliser.
There\'s no sense crying over every mistake.\r\nYou just keep on trying \'til you run out of cake.
Antknee
PostPosted: Tue Jan 04, 2011 5:32 pm Up
Give this a try Smile
206info.co.uk/Forums/v...ogram.html
chunkielad
PostPosted: Tue Jan 04, 2011 5:37 pm Up
I assume your key is the second on in the link above?
If so mine is exactly the same and stopped doing pretty much everything after a battery swap. I had to do the reprogram 3 times before it worked. I think you may be rushing the times scales. Try again but make sure you do the times right (plus a bit to be safe)
If you do not try you will NEVER succeed!
toto
PostPosted: Tue Jan 04, 2011 5:39 pm Up
I don't think anythink fall when I changed the battery.If I didn't saw that but it did fall out,how can I fix it? P.S. Antknee,I"ve tryed that one,but my key is not like the one on the picture.I didn't work anyway
chunkielad
PostPosted: Tue Jan 04, 2011 5:42 pm Up
Post a pic of the key and also a pic of the inside of the remote part then we can see which programming method you need and if the transponder has fallen out.
toto
PostPosted: Tue Jan 04, 2011 6:22 pm Up
It was the transponder.I forgot that first I've changed the case,it was no marking on the transponder.I opened a key from my old peugeot and it was marked "CP".On my mine it just looked like plastic in the corner.Lucky that I saved the old case.Thank you everyone.
