Posted: Tue Jan 04, 2011 3:03 pm |
My car won't start with my 2 plip key.It opens the doors,but it won"t start.I have a spare one ,but how do I fix the plip one.I tryed www.programyourkeys.com but it doesn"t work.I have a key code,but don't know what to do with it.My car it's 1.4 hdi.please I need advice
| be who you are and say what you feel.for those who mind it wouldn\"t matter.for those who matter,it wouldn\"t mind | |
Posted: Tue Jan 04, 2011 3:05 pm |
Did they key ever work?
Posted: Tue Jan 04, 2011 3:56 pm |
I bought the car last week,I think it worked then.But I changed the batery.Does that have something to do with the key not working
Posted: Tue Jan 04, 2011 4:00 pm |
What year is the 206?
'51 plate or newer, did you disconnect the battery right?
Does the spare one work ok?
is the battery the right one/ right way round lol and does the "blip" key start the car or just tern it over?
"edit" car battery or key battery lol
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Tue Jan 04, 2011 4:12 pm |
The other key works fine,the battery is "right" one as well.I've changed the key battery as well.The car is 51 plate,2002.They just quote me 70J to program it.Damn
Posted: Tue Jan 04, 2011 4:30 pm |
Did any small pointless looking bits of plastic fall out when you changed the battery? If so that'd be the transponder chip that disables the immobiliser.
| There\'s no sense crying over every mistake.\r\nYou just keep on trying \'til you run out of cake. | |
Posted: Tue Jan 04, 2011 4:32 pm |
Posted: Tue Jan 04, 2011 4:37 pm |
I assume your key is the second on in the link above?
If so mine is exactly the same and stopped doing pretty much everything after a battery swap. I had to do the reprogram 3 times before it worked. I think you may be rushing the times scales. Try again but make sure you do the times right (plus a bit to be safe)
Posted: Tue Jan 04, 2011 4:39 pm |
I don't think anythink fall when I changed the battery.If I didn't saw that but it did fall out,how can I fix it? P.S. Antknee,I"ve tryed that one,but my key is not like the one on the picture.I didn't work anyway
Posted: Tue Jan 04, 2011 4:42 pm |
Post a pic of the key and also a pic of the inside of the remote part then we can see which programming method you need and if the transponder has fallen out.
Posted: Tue Jan 04, 2011 5:22 pm |
It was the transponder.I forgot that first I've changed the case,it was no marking on the transponder.I opened a key from my old peugeot and it was marked "CP".On my mine it just looked like plastic in the corner.Lucky that I saved the old case.Thank you everyone.
