Posted: Wed Jan 05, 2011 6:41 pm |
mattievrs wrote: |
namgaj wrote: |
mattievrs wrote: |
^^^ As above but instead of the puller, put the wheel back on and use it to rock the drum outwards and itll come off easier then |
I tried EVERYTHING with mine and nothing would budge them!!!! (apart from a puller) |
Weak |
Even a few mechanics tried, at one point we were contemplating angle grinding them off, and replacing lol
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
Posted: Wed Jan 05, 2011 6:42 pm |
haha i tried using the wheel but that didnt budge it was like it was welded on or something! i hate drums they are ugly, hard to maintain and fix and just a general pain in the a**e
Posted: Wed Jan 05, 2011 6:57 pm |
if you havent got a puller follow these steps
jack car up and put axle stand under it make sure its 100% secure!
undo the hub nut
lay under the car an kick the s**t out of the wheel till pulls the drum off with it. it will come eventually
Posted: Wed Jan 05, 2011 6:59 pm |
giveitsomebar wrote: |
undo the hub nut
lay under the car an kick the s**t out of the wheel till pulls the drum off with it. it will come eventually |
done that method many times on my old valvered corsa!
| NO LONGER ACTIVE ON THE FORUM | |
i personally wouldnt want to lie under the car if im honest
Posted: Thu Jan 06, 2011 2:44 am |
I wouldnt attempt it at all!! My daughters '99 plate 106 went to ATS and even with the right kit for the job they struggled. It's not expensive to get it done properly (unless it's totally kn**kered) and brakes are a saftey issue!!
