Posted: Thu Jan 06, 2011 4:41 pm |
Hi all,
My front drivers side has started knocking alot, over the tiniest of defect in the road it sounds like metal knocking on metal. there is no vibrating or pulling to a side
is this just a bush or something? are there any common issues with 206 suspension?
the car has been lowered in the past so wouldnt suprise me if a bush has worn!
Posted: Thu Jan 06, 2011 4:42 pm |
Does the sound come from high up? Could be the top mount bearing. Or a drop link.
Posted: Thu Jan 06, 2011 4:45 pm |
Cant really tell to be honest, I checked to see if the drop link had snapped but it seems tight, havent had the car up in the air yet though.
Posted: Thu Jan 06, 2011 7:23 pm |
Posted: Thu Jan 06, 2011 8:13 pm |
They are drop links which connect to the anti roll bar! Yes as stated before it will be these that are knackered. Only a 10 minute job! I would do both sides as if one is gone chances are the other will be close to going as well
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Fri Jan 07, 2011 5:13 am |
i have had the same thing over the last couple of days happen but dosnt sound like meta on metal just sounds like a knocking sort of sound hard to explain. would this be the same
Posted: Fri Jan 07, 2011 5:30 am |
Yes it is the first part of the suspension to go. It is because of all the holes in the road just now!
Posted: Fri Jan 07, 2011 5:34 am |
cool are they easy to fit i know someone said it is a 10 minute job but i have no idea where these are hehind the wheel and how easy they are to do
Posted: Sat Jan 08, 2011 7:55 pm |
yep, anti roll bar, mine did the same thing, fixed within 15 minutes, noise disappeared
| Max Darby
Peugeot 206 Quiksilver, 1.4, 51 Reg, 34,000 Miles | |
Posted: Wed Jan 19, 2011 9:43 am |
Fixed this today.. turned out to be something completely different! ECU had somehow worked it's way loose.. tightened the bolt up... no more knocking
