Latest: elelectricistadeMateo
Overall: 17127
Online Now [70]:
Visitors: 69
Today: 25314
Total: 100397987
Forums › The Car › 206 Problems › Ice INSIDE My Car
Ice INSIDE My Car
JDave
PostPosted: Fri Jan 07, 2011 6:54 am Up
Hi,
Went into my car yesterday after work and the inside of the windscreen was frozen. i.e. I had to scrape the frost from the inside.
What the hell? I cannot fathom why this is.
Any ideas?
JD
Click To View My Project
Mine does it too.. annoying as it then goes all over the dash
Ali_H
PostPosted: Fri Jan 07, 2011 6:55 am Up
Condensation has frozen.
kurtis wrote:
MrrNoName
this happens in my GF's car, somehow moisture got inside the car onto the window, and it got below freezing and froze onto the window on the inside.
could be because the car has a small leak and water got in and attempted to evaporate. or could be because you sat in the car a while after it was turned off before you got out. causing the windows to steam up. which then froze over night Razz
bertt
PostPosted: Fri Jan 07, 2011 6:56 am Up
yeah condensation freezing as Ali_H said, could also be if some of the seals are going it will freeze up on the inside
PostPosted: Fri Jan 07, 2011 6:57 am Up
Defrost your windows (spend tenminutes heating car on with blowers on full.)
Then wipe all the moisture off the windscreen.
Give a good clean with some decent window cleaner and some newspaper.
Should stop it freezing. Smile
Either that and/or when driving put your blower onto taking air from outside rather than re-circulating. Then when stopping (and leaving overnight) make sure that no moisture is on the inside. Smile
Jono
PostPosted: Fri Jan 07, 2011 7:02 am Up
Don't use de-icer on the inside, I did this in my mini once and was high on areosols by the time I got to work!!
Had a - '99 Firedance 138 GTi - Broken
Then a - '10 Corsa - Hire Car
Now a - '56 A3 2.0TDi - Current Car
EuroPeugeot
PostPosted: Fri Jan 07, 2011 7:11 am Up
Rolling Eyes DOH!!!
giveitsomebar
PostPosted: Fri Jan 07, 2011 7:18 am Up
mine does this aswell, also fell to the de icer on the inside highness aswell!
JDave
PostPosted: Fri Jan 07, 2011 7:45 am Up
Newspaper?
Yes newspaper. Wink
JDave
PostPosted: Fri Jan 07, 2011 7:48 am Up
And do what with it?
PostPosted: Fri Jan 07, 2011 7:50 am Up
White vinegar and newspaper are the best things to clean windows
juanfernandes
PostPosted: Fri Jan 07, 2011 7:52 am Up
To clean the inside of the windscreen - works wonders!
Quote::
juanfernandes
I thought this post was going to be Audio related!
Quote::
