Posted: Sat Jan 29, 2011 3:49 pm |
Hey guys,
My handbrake needs tightening up badly (10 -12 clicks atm) and i havnt got a clue how to do it!! Would anyone be able to come a do it for me and ill pay (obviously!). Its a 1999 1.4 8v. Cheers guys. Joni!
Posted: Sat Jan 29, 2011 3:51 pm |
Have a look in the how-to section... Author is Gaz-RG.
Posted: Sat Jan 29, 2011 4:09 pm |
Lift your handbrake gaiter up and there will be a small nut turn it clockwise
Posted: Sat Jan 29, 2011 5:42 pm |
tomd0801754 wrote: |
Have a look in the how-to section... Author is Gaz-RG. |
Fame at last
Yep it's a very easy job to do. If I could do it, anyone could
| '98 MGF 1.8i
Team: ex-206 owner
Team: Roof is always down when it's not raining! | |
Posted: Sun Jan 30, 2011 6:18 am |
ok guys ill have a go, is it just really lifting the handbrake up to 4/5 clicks then tightening the bolt? sounds easy enough!
Posted: Sun Jan 30, 2011 8:18 am |
You need to make sure the rear brakes are working & adjusted correctly before you adjust the handbrake cable.
In normal use & if the brakes are looked after the handbrake cable should hardly ever need to be adjusted.
Posted: Mon Jan 31, 2011 8:17 am |
jonny_fulton03 wrote: |
ok guys ill have a go, is it just really lifting the handbrake up to 4/5 clicks then tightening the bolt? sounds easy enough! |
yep
