Posted: Wed Feb 09, 2011 6:27 am |
was thinking of changing my steering wheel, the current one is very worn :s.
should i get a custom one, maybe a V2, or should i just get a standard 206 one.
problem will be the airbag as if i remove it, it might mess up the sensors and MOT will fail, etc.
any ideas?
| 206 GLX, 1.4L Petrol, blue, First car and loving it | |
Posted: Wed Feb 09, 2011 6:30 am |
Just get a gti one much much much better feels nice and cheap, easy to fit
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Wed Feb 09, 2011 6:32 am |
if you buy an aftermarket wheel a decent one will come with a resistor which makes the car think it still has an airbag fitted and the light doesnt come on
Posted: Wed Feb 09, 2011 6:36 am |
Depends on what you want it for tbh, custom steering wheels are normally quite expensive for what you get, aftermarket steering wheels will require a hub adapter kit which range from 60 to 170 quid and will not have an airbag so the light will be on unless you bypass it and a 206 standard wheel would be the easiest option as it should bolt straight on and away you go although best to be fitted by a professional as messing around with airbags can have serious consequences as a mate of mine found out in his Fiesta Zetec S when he was driving it and parked turned the steering wheel to full lock and it deployed broke his nose but was absoulty hilarious.
The other option is to find a upholsterer and have him trim your current one in leather for you shouldn't set you back to much and there are a lot of options to choose from.
Hope this helps mate.
| 206 GTi 140, K&N Panel Filter, 180 Torsion Bars, Powerflex Rear Bushes. FK Coilover Kit, EBC Greenstuff Brake Pads, EBC Brake Discs, Braided Hoses.
www.206info.co.uk/Foru...tml#297897 | |
Posted: Wed Feb 09, 2011 6:51 am |
yeah id say get a leather gti one i did as my old one was really worn , new ones much better feels nice and looks better and more grip too.
Also can get them for £25ish on ebay.
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Wed Feb 09, 2011 6:55 am |
Rob206GTi wrote: |
Hope this helps mate. |
hahahaha that sounds hilarious!
Can i use my glx boss for the GTI steering wheel?
Posted: Wed Feb 09, 2011 7:36 am |
Yea i know mate had me in a fit of laughter for 10mins , yea should fit youll need to check the fitment but most models use the same boss kits throughout the model range only normally a bolt in the centre of the steering wheel and then some wires to connect to the horn and airbag module.
Posted: Wed Feb 09, 2011 7:40 am |
pretty sure the only difference between the wheels is the way the airbag is mounted inside the wheel someone with a bit more knowledge should be able to point you in the right direction with that though!
Posted: Wed Feb 09, 2011 8:08 am |
ok cheers, ill have to look into that then
Posted: Thu Feb 10, 2011 10:00 am |
giveitsomebar wrote: |
if you buy an aftermarket wheel a decent one will come with a resistor which makes the car think it still has an airbag fitted and the light doesnt come on |
& come 2012 it will fail the new tougher mot test
Airbag has to be fitted & the warning light has to operate correctly
