Forums › Tuning, Modification & Legal › Project Cars › Macs rally 206 project..latest rolling road results 200+hp |
Posted: Tue Feb 22, 2011 4:12 pm |
How the hell did you manage that??!
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Tue Feb 22, 2011 5:32 pm |
It was a dip in the tarmac in the paddock section of the stage.... just hit it fast and took off
Posted: Sun Apr 03, 2011 11:00 am |
Just a quick update..... We have just walked the test venue and should be able to set up a nice stage for testing, I am going to make up some pace notes so anyone who fancies a go in the co-drivers seat can have a go at reading their way round a stage.... should be fun
We are waiting on confirmation from the landowner that he is not double booked and the gearbox to arrive back in time for it to all take place... As for numbers... can you add your name to the list if you want to come along for a look on the "Test Day" thread.... thanks
Posted: Mon Apr 04, 2011 6:06 am |
Shame mine aint ready i wouldve brought it down for a good shakedown
| 1.6 XSi Stage Rally Car Build In Progress | |
Posted: Mon Apr 04, 2011 10:25 am |
How far away are you with the build..... Mine ended up taking 2 years in reality.... and I am always tweaking bits I think I can improve on , hence testing
Posted: Mon Apr 04, 2011 11:08 am |
st3v3n wrote: |
Looks normal to me Mac. Here's a pic of mine from the front end on a hairpin.You can see the inside rear lifting which means the outside rear has the full weight on it so will be compressing the wheel up into the arch. With the lighter rear end in a rally car, you can't always assume thicker ARBs will fix things as they will just cause the inside to lift more. I'd be experimenting with different torsion bars too. If you can get a few different ones then a decent mechanic with you who can swap them quick enough, you'll see what results you get on the test day.
A stiffer front end would keep the inside rear on the ground more.
Posted: Mon Apr 04, 2011 11:12 am |
Edward wrote: |
st3v3n wrote: |
A stiffer front end would keep the inside rear on the ground more. |
Good point.... I have big springs on the front and custom Gaz dampers, May be why my rear dont lift
Posted: Mon Apr 04, 2011 11:24 am |
If the rear isn't sliding though then there's nothing to gain from putting the wheel back onto the tarmac!
Posted: Tue Apr 05, 2011 1:45 am |
macj wrote: |
How far away are you with the build..... Mine ended up taking 2 years in reality.... and I am always tweaking bits I think I can improve on , hence testing |
I've not touched mine for near on 6 months now due to moving house and trying to get money together to buy my newborn the stuff it needs.
The cars at my parents house which is 20 mile away from where i live now so im trying to get the car moved up to my partners mums house and im going to keep it there so i can work on it every sunday. Got the majority of the parts needed now need to buy a few other things but most of it is stored ready to go.
Posted: Sun Apr 17, 2011 8:03 am |
Update... We had a mixed day testing, Started out on Toyo R888 tyres and did a few laps to warm them up....
We recorded a time of 1min 51seconds. First thing that became obvoius was the steering geometry was miles out after Brands Hatch tarmac. I decided to stop and alter the front toe-in by 1/2 a turn on the tracking and try again. This was a marginal improvement and resulted in a quicker stage time, 1 min 48 seconds. Once I had got use to the stage and we could eliminate the "Experience" factor we started to get results to within a second a lap. 1 min 46 seconds.
Then we had a little off when I tried to push harder on a section round some earth mounds which were starting to clean up. I hit the mound on the F/N/S forcing the fan onto the radiator..... exit all the water
We removed the radiator which takes only 3 minutes on this car as we have modified it. The damage was right at the bottom of the core where the rad had bent and popped two of the cores from the bottom plate. Janine came to the rescue with the idea of putting some 2 pack epoxy resin on the damage. While she was off home to get the resin we cleaned up the area and "scratched" it up to give the epoxy something to key onto. Suffice to say we got the resin on and it seemed fine to go again, so we refitted the rad, filled it up with the finest spring water and it held for the duration.
We switched over to gravel tyres at this interval as there was a lot of loose on the concrete, we worked out that with the semi-slicks on it was like running on marbles where as the gravel tyres would bite in more and find the concrete. We also added another turn to the toe-in, making it one and a half turns in total.... I will put the guages on them today to find out the actual reading.
Back on the stages we pushed on with the timings and I noticed a vast improvement in the steering, It has become obvious that a 300mm steering wheel is too small, I need to bring it 50mm closer and have at least a 350mm diameter as it will give a little extra leverage in tight hairpins. The times were still around 1 min 45 seconds but it was not as tiring on the arms to get round the stage.
I took my youngest daughter round for a stage. My co-driver is 16 stone at the moment and my daughter is 6 stone 12 lbs...... result!... 1 min 41 seconds.. 4 seconds faster and she managed to record herself on her video phone for the whole stage.... good girl!!
We gained some damage on the day which adds up to:- A radiator, right-hand engine mount, a small dent O/S/R a bit of crazing in the laquer on the front bumber, and we destroyed a new set of gravel tyres.
All in all a good days testing, we have learnt a lot. A big thanks to John (Seabrook) for coming down... look forward to his pictures... Hope you enjoyed your hot lap and the BBQ after....
Posted: Sun Apr 17, 2011 8:16 am |
Thanks for organizing this event, i definitely have a good day!
was wondering what spring rate did you use for the front?
Posted: Sun Apr 17, 2011 8:49 am |
Would a normal front bumper be less likely to hit things???
Posted: Sun Apr 17, 2011 12:26 pm |
Edward wrote: |
Would a normal front bumper be less likely to hit things??? |
Yes, but not half as much fun
Posted: Sun Apr 17, 2011 1:23 pm |
Posted: Sun Apr 17, 2011 1:42 pm |
Nice pictures mate.... I dont have facebook unfortunately but I am sure they will be good... thank you
