Latest: Andyblue64
Overall: 17123
Online Now [175]:
Visitors: 174
Today: 16233
Total: 97997402
Forums › The Car › 206 Problems › What to do?
What to do?
MutilateTheDead
PostPosted: Wed Apr 06, 2011 2:53 pm Up
Had my MOT on tuesday and one thing it failed on was ABS light on dash, i knew this would fail and had a driveshaft waiting as i knew my ABS sensor had snapped off, so i went to a seperate garage the same day as MOT and got my driveshaft fitted, picked it up today only for him to tell me that the other driveshaft sensor was snapped too, he jumped into the car before i left and pulled the ABS bulb out!!!! He said that he should of just done that in the first place, i have my car booked in for a re-test for 8am tomorow morning, what the hell should i do, i'm gonna feel like a right tw*t when it fails for not having an ABS bulb but i can't ring to cancel the re-test as it is at 8am when they first open! And if it fails again i'll have to pay for yet another full MOT Sad
206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out!
ma.langan
PostPosted: Wed Apr 06, 2011 2:56 pm Up
should pass i think because the bulb aint there to flash? they dont check dash board bulbs i dont think?
Farmer T'aaron!
PostPosted: Wed Apr 06, 2011 2:57 pm Up
If the light isn't on, they won't know that's the idea.
MutilateTheDead
PostPosted: Wed Apr 06, 2011 2:58 pm Up
But, isn't it supposed to show up on start? to show the bulbs working?
PostPosted: Wed Apr 06, 2011 2:59 pm Up
Hmm, don't know for sure why didn't you just mot at the garage that did the driveshaft?
PostPosted: Wed Apr 06, 2011 3:01 pm Up
Non working ABS warning light = FAIL Wink
MutilateTheDead
They don't do MOT's Sad
PostPosted: Wed Apr 06, 2011 3:07 pm Up
The first thing the mot tester is gonna do is check the abs warning light is operating correctly as that's why it failed last time.
Ring them first thing & rearange the retest for another day.
l_jacka
PostPosted: Wed Apr 06, 2011 3:13 pm Up
Will fail if the bulb isn't working unless you are mates with the garage people Wink Best to fix the problem rather than trying to beat around the bush
Looking to buy my first peugeot 206
PostPosted: Wed Apr 06, 2011 3:18 pm Up
Just cross your fingers VOSA aint hiding round the corner ready & waiting for one of there random inspections Laughing
pug206lx
PostPosted: Wed Apr 06, 2011 3:40 pm Up
Cowboys Laughing
MutilateTheDead
PostPosted: Wed Apr 06, 2011 3:57 pm Up
I've decided to cancel the re-test and ordered the other driveshaft from euro car parts, better to spend the little extra and be safe than bodge it i suppose Smile
panason1c
PostPosted: Thu Apr 07, 2011 4:26 am Up
The mot 'computerised' failure record will show on the retest that the reason for failure was an abs related fault, therefore, removing the bulb (as if abs was not fitted) will not work in this instance, even if you take it to another test station the original reason for failure will still show up on their computer. You need to rectify the fault before your retest.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
