Latest: Makomeister18274
Overall: 17122
Online Now [304]:
Visitors: 303
Today: 53826
Total: 97889022
Forums › The Car › 206 Problems › anti pollution
anti pollution
LilLew
PostPosted: Sat Jun 04, 2011 8:40 am Up
hey all me again just replaced the rear lambda sensor on my 206 gti 180again and i have cleared the error but it sill has the fault can any one advise on this
2003 Pug 206 2.0 GTI 180
PostPosted: Sat Jun 04, 2011 8:43 am Up
Who said it was Blank 1 sensor 2?
LilLew
PostPosted: Sat Jun 04, 2011 8:44 am Up
my ecu code reader p141 if i remember correctly
smiddies
PostPosted: Sat Jun 04, 2011 8:45 am Up
If the error code still coming up, then it means that part you changed wasnt faulty!
Also only use Peugeot Lamba Sensors Wink
LilLew
PostPosted: Sat Jun 04, 2011 8:51 am Up
this genuie pug parts it cost me just over 100 quid
albury1987
PostPosted: Sat Jun 04, 2011 8:57 am Up
my 180 kept coming up with that for about 2 months, had everything checked was all sweet but kept doing it. I thought i was something to do with emissions, but didnt seem to be. In the end i just put a scanner on it, and deleted it off as an error. It hasnt come up since, and 3 years later still not had any issues. Hope this helps, but it might just of been an error on mine.
next car 350z or rx7 hmmm
smiddies
PostPosted: Sat Jun 04, 2011 8:58 am Up
Is your code reader a specific peugeot one, if its a universal type one, then it could display a general code for the actual error,
Ie i once used my universal one on my pug, told me that one of my injectors went, but a peugeot code reader actually tells you the right injector, and obviously as its a french car, you count backwards when facing the car!
LilLew
PostPosted: Sat Jun 04, 2011 9:09 am Up
it was a universal reader i am waiing for my pug reader from ebay to turn up this os really doing my hea in my mot is the end of the month
PostPosted: Sat Jun 04, 2011 9:12 am Up
P0141 is a generic code anyway. Will be the same on all readers.
P0xxx = Powertrain Generic
LilLew
PostPosted: Sat Jun 04, 2011 12:38 pm Up
o ok nice to know still wonsering why this if happening
LilLew
PostPosted: Sun Jun 05, 2011 2:28 am Up
is there any weak points on the cars wiring where i could check
LilLew
PostPosted: Sun Jun 05, 2011 5:57 am Up
i have solved the problem now i have found two of the wires and been pushed out of the connector but only the smallest amount
