Latest: Andyblue64
Overall: 17123
Online Now [225]:
Visitors: 224
Today: 14280
Total: 97995468
Forums › The Car › 206 Talk › brake discs
brake discs
kris_19
PostPosted: Thu Jun 23, 2011 9:25 am Up
hi can some one tell me what is the best grooved or drilled ??...and please do you know the gti180 ones fit on a 1999 206??? 10x
eee
PostPosted: Thu Jun 23, 2011 9:27 am Up
Only one post is needed Kris.
Someone will answer your question soon
Andrew
PostPosted: Thu Jun 23, 2011 9:35 am Up
Drilled can become cracked due to large amounds of heat dissipating through a small area around the holes, I think grooved is better
Also its not as simple as just putting the disks on, you would need the calipers and setup from that model.
My 206 thread
www.detailedbyandrew.com
Lewis
PostPosted: Thu Jun 23, 2011 9:45 am Up
you couldnt just buy 180 discs for a normal GTI cause i beleive they are bigger. if you look on ebay Mtec do nice drilled and grooved disks for the peugeots.
Tivoli LX 1.1
Black GTI 180
White VXR Burg
PostPosted: Thu Jun 23, 2011 10:24 am Up
plain disc is excellent
PostPosted: Thu Jun 23, 2011 10:27 am Up
Absolutely no reason to fit anything but a plain vented disc on a 206.
NICKST
PostPosted: Thu Jun 23, 2011 11:03 am Up
Unless it's for better braking or looks. Might not be power full enough to need them but they would make difference.
Lecktorious
PostPosted: Thu Jun 23, 2011 11:06 am Up
Trade Rating: +59
I doubt you'd be using the brakes long enough on a road for drilled or grooved discs to be of any use over standard discs.
A better brake pad would be a better choice.
'98 Nile Blue 306 GTi 6
PostPosted: Thu Jun 23, 2011 11:10 am Up
Brembo discs with Ferodo Premier pads, all you need on a standard road going 206.
PostPosted: Thu Jun 23, 2011 11:14 am Up
do you really think those cheap nasty black dia**** or e*c drill/ groove disc is good for performance? Laughing
althought, however, i do believe those expensive WRC grade AP groove disc are build for performance. but that probably worth more than a 1.9D 206
PostPosted: Thu Jun 23, 2011 11:18 am Up
They look bling driving through McDonalds though isn't it Laughing
NICKST
PostPosted: Thu Jun 23, 2011 11:39 am Up
Specially if there on a 1.1 fiesta pop as I have just seen lol
kris_19
PostPosted: Thu Jun 23, 2011 12:06 pm Up
Ok 10x buddies for your advice Smile
eee
PostPosted: Thu Jun 23, 2011 12:07 pm Up
Brembo MAX discs or Brembo Easy Check discs
Ferodo DS Performance pads or Ferodo Premier Pads
