Posted: Thu Jun 23, 2011 9:25 am |
hi can some one tell me what is the best grooved or drilled ??...and please do you know the gti180 ones fit on a 1999 206??? 10x
Posted: Thu Jun 23, 2011 9:27 am |
Only one post is needed Kris.
Someone will answer your question soon
Posted: Thu Jun 23, 2011 9:35 am |
Drilled can become cracked due to large amounds of heat dissipating through a small area around the holes, I think grooved is better
Also its not as simple as just putting the disks on, you would need the calipers and setup from that model.
Posted: Thu Jun 23, 2011 9:45 am |
you couldnt just buy 180 discs for a normal GTI cause i beleive they are bigger. if you look on ebay Mtec do nice drilled and grooved disks for the peugeots.
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Thu Jun 23, 2011 10:24 am |
plain disc is excellent
Posted: Thu Jun 23, 2011 10:27 am |
Absolutely no reason to fit anything but a plain vented disc on a 206.
Posted: Thu Jun 23, 2011 11:03 am |
Edward wrote: |
Absolutely no reason to fit anything but a plain vented disc on a 206. |
Unless it's for better braking or looks. Might not be power full enough to need them but they would make difference.
| Image removed due to size
focus st 3 with pro alloy intercooler, 3" mongoose down pipe, 200 cell sports cat and mongoose cat back, collins bov, dreamscience dsci cold air intake,focus rs injectors,focus rs oil cooler,dreamscience dsci tuneing platform mod X map,focus rs clutch & flywheel, rs fuel pump, polly bushes in wish bones rear axal and suspension white line front and rear arb, eibach pro street s suspension. | |
Posted: Thu Jun 23, 2011 11:06 am |
Trade Rating: +59
NICKST wrote: |
Edward wrote: |
Unless it's for better braking or looks. Might not be power full enough to need them but they would make difference. |
I doubt you'd be using the brakes long enough on a road for drilled or grooved discs to be of any use over standard discs.
A better brake pad would be a better choice.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Thu Jun 23, 2011 11:10 am |
Brembo discs with Ferodo Premier pads, all you need on a standard road going 206.
Posted: Thu Jun 23, 2011 11:14 am |
NICKST wrote: |
Edward wrote: |
do you really think those cheap nasty black dia**** or e*c drill/ groove disc is good for performance?
althought, however, i do believe those expensive WRC grade AP groove disc are build for performance. but that probably worth more than a 1.9D 206
Posted: Thu Jun 23, 2011 11:18 am |
Seabook wrote: |
NICKST wrote: |
Edward wrote: |
They look bling driving through McDonalds though isn't it
Posted: Thu Jun 23, 2011 11:39 am |
MrBSI wrote: |
Seabook wrote: |
NICKST wrote: |
Edward wrote: |
They look bling driving through McDonalds though isn't it |
Specially if there on a 1.1 fiesta pop as I have just seen lol
Posted: Thu Jun 23, 2011 12:06 pm |
Ok 10x buddies for your advice
Posted: Thu Jun 23, 2011 12:07 pm |
Brembo MAX discs or Brembo Easy Check discs
Ferodo DS Performance pads or Ferodo Premier Pads
