Posted: Sun Apr 17, 2011 1:44 pm |
| macj wrote: |
| Nice pictures mate.... I dont have facebook unfortunately but I am sure they will be good... thank you |
pm me your address and i will post you the cd
probably can't email you the pics as they are too large lol
Posted: Sun Apr 17, 2011 2:05 pm |
PM done mate
Posted: Sun Jul 17, 2011 7:25 am |
Posted: Sun Jul 31, 2011 10:09 am |
Nice update to the project. Yesterday (saturday) I had a successful meeting with CTM Performance engineering who have agreed a sponsorship package for Engine tuning in the form of:-
1. Gas flowed head with big valves and three angle valve seats, bronze quides and welding up the EGR port in the exhaust, volume match chambers.
2. full bottom end balance and fitting forged rods.
3. port matching both manifolds and modifying the taper on the inlet manifold.
In all a very nice deal so the engine is off to them this week and then it will be refitted and sent down to Wiltshire for a re-map ready for the Hutton Kitchens Stages rally in Septenber.
Posted: Sun Jul 31, 2011 11:00 am |
Does he want to sponsor me as well??
Well done mate. We will need to get an event together some time!
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Sun Jul 31, 2011 11:31 am |
would be good to do an event together... how about the Dukeries next year?
Will let you know about the new engine and how it performs on the Hutton stages.... then point you in his direction.
Posted: Sun Jul 31, 2011 2:02 pm |
Trade Rating: +46
good news ......
Posted: Sun Jul 31, 2011 2:03 pm |
nice one macj.
you still running std cam?
Posted: Sun Jul 31, 2011 2:06 pm |
Sounds good. Would this all justify some longer duration cams?
Posted: Sun Jul 31, 2011 2:44 pm |
Ed.... in order to keep the torgue figures and the power curve in the lower part of the rev range, the tuner thinks we should keep the current stock profiles as aparently they are pretty close to the 230 duration he would be using anyway..... good news for me
Posted: Mon Aug 01, 2011 12:30 pm |
Posted: Mon Aug 01, 2011 1:35 pm |
Oops damn wiring!! Yeh Dukeries sounds good mate hopefully can have a 180 that wont blow up by that point haha 3 so far this year
Posted: Tue Aug 02, 2011 12:39 pm |
Anyone got a spare speed sensor for sale.....?
Posted: Fri Aug 05, 2011 5:27 am |
Quick update..... The old engine is on its way to the machine shop.
This engine has been used on various events and was bog standard except the T/B conversion which produced 183.2HP and an increase in torque
This has proved to be very reliable but has suffered from a lack of bottom end puff in hairpins and tight corners. The idea now is to take the engine to the next phase and add some internal mods.
1. big valve head
2. Forged steel "H" section rods
3 mild knife edging to crank
4. full balance.
All this is happening over the next couple of weeks and then the engine will come back to be re-fitted and RR tuning.
Progress will be posted
Posted: Fri Aug 05, 2011 5:41 am |
nice one macj.
so bascially a TB gti can blow away stock 180gti easily
