Latest: Worthy967
Overall: 17143
Online Now [185]:
Visitors: 184
Today: 26020
Total: 115857329
Forums › The Car › Solved 206 Problems › Spacer seized
Spacer seized
PostPosted: Wed Sep 14, 2011 6:18 am Up
The spacer has seized onto the inside of Georgie's wheel Sad
I have tried hitting it with a rubber mallet and soaking it in penetrating spary and its not shifting.
Any sensible suggestions?
ExoVyper
PostPosted: Wed Sep 14, 2011 6:24 am Up
the only thing i can think of is tapping a small thin screwdriver behind it to try and ease it off
othwise i'm stumped
Uz
PostPosted: Wed Sep 14, 2011 6:31 am Up
I just took an old extension bar and a lump hammer to mine when they need to come off and after a few even hits around the spigot they just came off.
00budham00
PostPosted: Wed Sep 14, 2011 6:34 am Up
That's the problem with aluminium spacers the corrode to the alloy wheel ! I would try the Hitting the screw driver from behind the spacer coming though the wheel holes
PostPosted: Wed Sep 14, 2011 6:45 am Up
We have tried with a screw driver it won't budge :/ so we're gunna take it down the place we get our wheels from ask them if they can remove it Razz
PostPosted: Wed Sep 14, 2011 6:48 am Up
this happened to me so we put big fat bolt through one of the holes and hit it with a big hammer and after a few taps they came off, oh and loads of WD
PugJH
PostPosted: Wed Sep 14, 2011 7:27 am Up
Shame the hubs dont have studs as i'd sit the spacer on that and knock the wheel off it.
Basically what Jord said, but easier
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Wed Sep 14, 2011 7:37 am Up
never happen on mine and as a rule of thumb is your should grease the hubs surface before you put the wheels on.
gazza82
PostPosted: Wed Sep 14, 2011 8:09 am Up
Copperslip is better ... copes with high temps which you get next to the brakes.
Antknee
PostPosted: Wed Sep 14, 2011 8:16 am Up
Got a puller?
PostPosted: Wed Sep 14, 2011 10:26 am Up
Sorted now, thanks guys Smile
Antknee
PostPosted: Wed Sep 14, 2011 11:40 am Up
How did you do it in the end?
PostPosted: Wed Sep 14, 2011 11:52 am Up
What He Said
Copper grease or white lithium.
Always put it on the back of wheels too Smile
Mrs_Howey
PostPosted: Wed Sep 14, 2011 12:00 pm Up
The place we get all our tyres from, one of the took a hammer to it, but now it's bent flat on one side now. But it's off from my wheel as i was swopping the 20mm spacers for 10mm spacers to stop the scrubbing on the rear.
Smile
I have them all copper greased up now Razz
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
Mattie-RS
PostPosted: Wed Sep 14, 2011 12:01 pm Up
What She Said
