Posted: Sun Oct 02, 2011 6:35 am |
Hi i changed my 180's brake master cylinder yesterday it was all going really smoothly until ive come to bleed the brakes i can't get any pressure at all the pedal just drops straight to the floor, am i now right in thinking it will need pressure bleeding on peugeot planet or at a garage who has similar equipment?.
Posted: Sun Oct 02, 2011 6:37 am |
180 brakes need to be bled using PP IIRC. How far away from Sheffield are you?
Posted: Sun Oct 02, 2011 6:40 am |
About an hour and a half.
Posted: Sun Oct 02, 2011 8:02 am |
Another 180 with non working brakes thanks to DIY repairs
2nd one in the last few weeks
Posted: Sun Oct 02, 2011 8:09 am |
Yeah dead funny Mr bsi
Posted: Sun Oct 02, 2011 9:05 am |
Trade Rating: +31
Thanks for posting this! I was going to change the brake fluid myself but won't do it now knowing this!
Posted: Sun Oct 02, 2011 9:08 am |
Andy180 wrote: |
Yeah dead funny Mr bsi |
There has been enough warning posted up on here over the years about the 180 brake system needing Peugeot Planet to bleed it
Posted: Sun Oct 02, 2011 10:21 am |
Fair enough, can't see why you found it so funny though .
Posted: Sun Oct 02, 2011 10:36 am |
I changed my brake fluid 3 weeks ago, I have no problems braking
why do you need PP to bleed it?
| 03, RC / GTI180
03, SW XSI | |
Posted: Sun Oct 02, 2011 10:49 am |
Daniel206RC wrote: |
why do you need PP to bleed it? |
If you manage to get air inside the abs hydraulic modulator while attempting to bleed the brakes you will then need to activate the valves inside the ABS / ESP unit to bleed the system successfully
Posted: Sun Oct 02, 2011 11:36 am |
okey, I changed to Brembo calipers and then changed the brake fluid with pressure on the system.
So maybe I made it without getting air into the system..
| 03, RC / GTI180
03, SW XSI | |
Posted: Sun Oct 02, 2011 11:54 am |
So in fact this could apply to all 206's with ABS. You dont need PP, You just need to do it properly.
Posted: Mon Oct 03, 2011 8:04 am |
Steve206 wrote: |
So in fact this could apply to all 206's with ABS. You dont need PP, You just need to do it properly. |
Nope, only 206's with ESP fitted which is GTI 180 / RC & some newer GTI's.
If you do manage to get air inside the hydraulic modulator you WILL then need Peugeot Planet to bleed the brake system.
Posted: Mon Oct 03, 2011 8:09 am |
I fitted brembos a while back, along with a new master cylinder. And I couldn't get any pressure in the system either.
Ended up taking it to a friend's garage who pressure bled it. Pretty sure they didn't use Peugeot Planet thou..?
| 206 GTi 180 - 406 brembos with 283mm discs, coilovers and Sparco bucket seats | |
Posted: Mon Oct 03, 2011 2:51 pm |
Its getting trailored to a mates garage to be pressure bled now.
