Latest: tbafonso
Overall: 17130
Online Now [364]:
Visitors: 363
Today: 55088
Total: 104244710
Forums › The Car › 206 Problems › Annoying squeak!!
Annoying squeak!!
danlouiee
PostPosted: Fri Dec 30, 2011 6:22 pm Up
Tonight I lft the misses house about 11 and drove about a mile to the petrol station before I came home. On cold damp mornings my car has been making squealing noises on light acceleration, like it's wet until its warmed up and dried..but it did it almost all the way to the petrol station tonight until I filled up started the engine again, it sounded like it slipped and then it was fine? Any suggestions?!
I've done a search but I didn't know if anyone else was getting this problem with the winter weather and found a solution?
Big_Rich180
PostPosted: Fri Dec 30, 2011 6:28 pm Up
Could be a mouse....
Maybe an aux belt slipping??
How do you mean its wet until its warmed up?
You say its slipped...whats slipped.
Where is the squeak coming from??
danlouiee
PostPosted: Fri Dec 30, 2011 7:05 pm Up
Well when I say slip its like it's slipping that's what I presume, but it only happens when it's cold and wet on first start up, but as the engine warms and it runs it stops? It's coming from under the bonnet I know that but by the time I've started it popped the bonnet to have a gander it's gone!:(
jcowan
PostPosted: Fri Dec 30, 2011 8:15 pm Up
Its a belt im sure, mine does the same thing.
2003 1.4 LX Silver.
-Dave-
PostPosted: Sat Dec 31, 2011 12:40 am Up
Trade Rating: +36
Aux belt I would say. Cheap enough to replace so change it and see if problem persists.
Ex 206 Owner.
AshH
PostPosted: Sat Dec 31, 2011 4:02 am Up
What they all said Aux belt is slipping!!!
Team - 180
Team - ATM!!!
gixxerkev
PostPosted: Sat Dec 31, 2011 4:41 am Up
If its the Aux belt slipping that would mean the tensioner is on its way out and needs replacing, the squeak could also be the tensioner bearing seizing up. Get it replaced soonest because if the belt snaps or comes off you'll have no alternator, air-con or power steering.
An Ex '03 1.4 GLX driver, German technology all the way now.
Razor34
PostPosted: Sat Dec 31, 2011 4:57 am Up
Definitely aux belt and tensioner spring. I had mine replaced recently because of the same problem you are having and it is now fine. Total cost £175.00 for me was unless you do it yourself.
Ray
Abzynthe
PostPosted: Sat Dec 31, 2011 4:58 am Up
East Area Rep - Abzynthe
Really?
My local garage did if for £54
Razor34
PostPosted: Sat Dec 31, 2011 5:01 am Up
That's good - did they actually charge labour lol!!!
TBH I was just glad to get it done
Ray
Abzynthe
PostPosted: Sat Dec 31, 2011 5:07 am Up
im not sure lol. I've been going to him for a while to the point where everytime I turn up he immediately asks "Whats up with it now?!?" Laughing
Razor34
PostPosted: Sat Dec 31, 2011 5:16 am Up
LOL I'm new to Peugeot but now learning very quickly how much they cost Very Happy
Ray
gixxerkev
PostPosted: Sat Dec 31, 2011 6:11 am Up
Yep they're expensive for a little car, I used to think my Alfa 156 was expensive until I got a 206, seem to be spending all the time lol !!!!
PostPosted: Sat Dec 31, 2011 6:12 am Up
Only if you buy a bad one Wink
-Dave-
PostPosted: Sat Dec 31, 2011 6:15 am Up
Trade Rating: +36
Depends on how you look after it to how much it will cost you. If you drive and maintain your car regularly most things will be simple wear and tear. Had mine over a year now and apart from clutch and aux belt nothing has gone wrong as it was looked after before I got it and still is.
Ex 206 Owner.
