Latest: Andyblue64
Overall: 17123
Online Now [42]:
Visitors: 41
Today: 13439
Total: 97994631
Forums › The Car › 206 Problems › Bsi - complete set off another car, will it work?
simon_p
PostPosted: Wed Mar 14, 2012 11:08 am Up
Basically as the title says? I strongly believe mines packed up and sourcing a second hand one for a 1.6 cc is a mare.
If I was to get the full ecu/bsi and key set off a different car but it wasn't the identical number to mine (as printed on the sticker) would it still work?
Simon
Peugeot 206cc SPL build
2011 - 2 vibe 12" spaces, 38hz ported box, 2.5k Ground zero Nuclear mono - 141.2db @ 38hz
2012 - GZ Nuclear 12"s, 33hz box, 2 x 2.5k GZ Nuclear monos, 8" GZ comp mids, 4" GZ tweeters - 144.0db @40hz off 1500wrms
build thread -http://www.206info.co.uk/Forums/viewtopic/p=486554.html#4865540
PostPosted: Wed Mar 14, 2012 11:13 am Up
I think so. You would need ECU, BSi, IMMO and transponder chip. One of the Lee's will confirm/rubbish that.
However, why do you think yours is knackered?
PostPosted: Wed Mar 14, 2012 11:32 am Up
Yes, but you need to make sure you have a multiplexed set if your mulitplexed or pre-plexed if your pre-plex. You will need the whole set ECU, BSI, transponder ring for the ignition barel & the transponder chip for the key.
Rob2859
PostPosted: Wed Mar 14, 2012 12:12 pm Up
It may still need configuring to the car. For example my speedo did not work as the car it was off had ABS so it was not getting a reading. It needed changing to the gearbox sensor which Lee kindly did for me.
PostPosted: Wed Mar 14, 2012 2:14 pm Up
A hatchback one will need configuring for the folding roof ECU to be enabled.
simon_p
PostPosted: Thu Mar 15, 2012 5:35 am Up
It's ok. I'm sorted. I had all the symptoms according to posts all over the Internet of a failed bsi. Turns out just a fuse had blown, but somehow was still getting a continuity reading when still in the board
