Latest: Andyblue64
Overall: 17123
Online Now [146]:
Visitors: 145
Today: 76452
Total: 98348006
Forums › The Car › 206 Problems › 2.0 hdi oil leak
2.0 hdi oil leak
Abzynthe
PostPosted: Tue Apr 17, 2012 8:29 am Up
East Area Rep - Abzynthe
Howdo,
I was putting my new dampers on my engine last night and i noticed a lot of oil around the oil cap and in the head below.
I suspect its the gasket thats gone.
I've checked my oil and its still on the max mark, but I was wondering, to change the gasket, do I need to drain the oil at all of can I just unscrew all the bolts and change it?
I've added a pic to show you where the leak is coming from.
P.s. - would this affect power or anything? I havent noticed anything, but then again I dont know how long its had a leak.
Big_Rich180
PostPosted: Tue Apr 17, 2012 8:31 am Up
If its on the cam cover you shouldnt need to drain any oil.
Abzynthe
PostPosted: Tue Apr 17, 2012 8:38 am Up
cool Smile
Got a job this weekend then lol. Best see if my local gsf has a gasket Smile
frankaai
PostPosted: Tue Apr 17, 2012 8:51 am Up
nah mate dont need to drain any oil at all, if i was you i would put a tiny smear of sealer on the new gasket just to make it extra tight! i know other people would disagree but thats what i would do Smile
frankaai
PostPosted: Tue Apr 17, 2012 8:54 am Up
or even just put a bit of sealer on your old gasket, preferably black, would save you a couple of pound on a new one
Abzynthe
PostPosted: Tue Apr 17, 2012 8:55 am Up
Quick question, is it just the 6 torx bolts and lift it off or do I have to remove the pipes attached to it aswell?
Might aswell just get a new one Smile £14.97 from Eurocarparts, should be cheaper at gsf as I get 20% discount.
frankaai
PostPosted: Tue Apr 17, 2012 9:12 am Up
yes pull back the pipes as well, you need to take all screws out, just lift it with a flat head screw driver, go easy though, clean the whole thing, inside and out, you could even spray it while its off if you wanted lol dont tighten the screws to much though incase they snap
Abzynthe
PostPosted: Tue Apr 17, 2012 9:22 am Up
Thanks Smile
No point me spraying it. Ive got an engine cover for it Laughing
frankaai
PostPosted: Tue Apr 17, 2012 9:27 am Up
no worries matey, i need an engine cover for mine Sad
Abzynthe
PostPosted: Tue Apr 17, 2012 9:28 am Up
Got mine off ebay for a tenna Smile
Pug want £180 for a brand new one Laughing
If you cant find one for the 206, other peugeot/citreon 2.0 hdi's have the save cover. Mines off a 406 Smile
frankaai
PostPosted: Tue Apr 17, 2012 9:44 am Up
yeah il have to take a wee look sometime, trying to sort out the ugly green interior at the min, its clashing with my half leather interior..... lol
frankaai
PostPosted: Tue Apr 17, 2012 9:51 am Up
sorry meant half leather seats
drunknmunky
PostPosted: Tue Apr 17, 2012 10:52 am Up
might just be me being picky here but aint you meant to get the head skimmed aswell at an engineering place to allow for a good seal i did last time i changed one on a saxo?
frankaai
PostPosted: Tue Apr 17, 2012 11:07 am Up
It's not the head gasket it's only the rocker cover gasket, you only get your head skimmed if the engine has over heated and it's warped, the head is only aluminium and it can bend when over heated that's the only time it needs skimmed
drunknmunky
PostPosted: Tue Apr 17, 2012 11:08 am Up
ahhh i see fair enough its been a while since i done one you see so didnt really take a proper look Laughing
