Latest: TigerHunters
Overall: 17144
Online Now [53]:
Visitors: 52
Today: 40215
Total: 115871312
Forums › The Car › 206 Problems › Heavy Clutch Pedal, an effort to push down
borinous
PostPosted: Fri Apr 20, 2012 3:18 am Up
I find that the clutch pedal on my 2003 1.4 8v lx is quite heavy compare to other vehicles i have owned.
Is this normal or is there an issue with say the clutch cable?
Hi
PostPosted: Fri Apr 20, 2012 3:21 am Up
I wonder if its the clutch/thrust bearing about to go. I had the same hard feeling in my old 206, the clutch was replaced after the thrust bearing went then after that the clutch pedal was so soft I was nearly stalling because I wasnt used to it!
borinous
PostPosted: Fri Apr 20, 2012 3:24 am Up
Clutch and bearing have been recently (~2000miles ago) replaced
Hi
frankaai
PostPosted: Fri Apr 20, 2012 3:32 am Up
did you just buy this 206 recently? or has it all of a sudden started feeling heavy?
borinous
PostPosted: Fri Apr 20, 2012 4:13 am Up
well "we" have owned the 206 for over a year..the missus was using it but then we had a shake up of cars and i ended up with it.
it was in our possesion when the clutch was changed but as i did not drive it daily i cannot comment on if the pedal was heavier or lighter after the change.
Now its my daily and when i hit traffic i now notice how heavy it is.
Hi
PostPosted: Fri Apr 20, 2012 5:15 am Up
Every 1.4 I've driven has allways had a heavyish clutch.
borinous
PostPosted: Fri Apr 20, 2012 6:11 am Up
Thats fine by me..just wanted to check incase i was facing sudden failure of something. I only notice it when im driving in traffic.
Hi
ARRAN
PostPosted: Fri Apr 20, 2012 6:59 am Up
Mine was quite heavy, could just be wear. I've just had mine replaced as it was knackered, now its light as a feather.
See my project here.
lofty
PostPosted: Fri Apr 20, 2012 9:49 am Up
Mine is heavy in the gti. Any simple/cost effective ways of improving it slightly?
206 GTI
Nimrods
SP Grille
Cargo Net!
Leader Team: Tivoli GTI
Leader Team: Cargo Net
Snowboard & Bindings For Sale
