Posted: Wed Jul 18, 2012 1:03 am |
I have a pug 206 2001 1360cc it is misfiring on number 4 cylinder computer says injector fault fitted new on also changed the coil pack plugs checked the wiring and had the e c u checked out still misfiring computer still say injector fault any Ideas im out of them
Posted: Wed Jul 18, 2012 1:27 am |
did you change the correct one?
Posted: Wed Jul 18, 2012 2:43 am |
Number 4 is the TIMING BELT end.
Posted: Wed Jul 18, 2012 3:37 am |
MrBSI wrote: |
Number 4 is the TIMING BELT end. |
Are you sure?
Posted: Wed Jul 18, 2012 3:54 am |
paul_c wrote: |
MrBSI wrote: |
Are you sure? |
He used to work at Peugeot Dealers, he'll be sure.
Posted: Wed Jul 18, 2012 4:28 am |
No worries, the only reason I ask is that by convention, almost all inline engines have their cylinders numbered with 1 starting at the pulley (non flywheel) end. If its the case though, it certainly explains the original poster's issue!
Posted: Wed Jul 18, 2012 5:24 am |
paul_c wrote: |
No worries, the only reason I ask is that by convention, almost all inline engines have their cylinders numbered with 1 starting at the pulley (non flywheel) end. If its the case though, it certainly explains the original poster's issue! |
Peugeot like doing things backwards. Inj 1 is gearbox end.
Posted: Wed Jul 18, 2012 5:44 am |
paul_c wrote: |
MrBSI wrote: |
Are you sure? |
100% sure, that's why injector 4 always failed first because of the bonnet vent
Posted: Wed Jul 18, 2012 5:49 am |
Seabook wrote: |
paul_c wrote: |
MrBSI wrote: |
Are you sure? |
100% sure, that's why injector 4 always failed first because of the bonnet vent |
Its NOT the bonnet vent
Its the washer jet, rain water leaks behind the washer jet & drips straight down on to number 4 injector, thats why 206's with the under bonnet cover dont seem to suffer from injector failures.
Posted: Wed Jul 18, 2012 5:50 am |
MrBSI wrote: |
Seabook wrote: |
paul_c wrote: |
MrBSI wrote: |
Are you sure? |
Its NOT the bonnet vent |
ok, leaky windscreen pipe then
Posted: Wed Jul 18, 2012 5:52 am |
paul_c wrote: |
MrBSI wrote: |
Are you sure? |
100% sure, seen no end of people change the wrong injector on PSA stuff as they think that number 1 is timing belt end - NOT in PSA world its not
Posted: Wed Jul 18, 2012 5:59 am |
Ash wrote: |
He used to work at Peugeot Dealers, he'll be sure. |
I have never worked for Peugeot or Citroen.
I have had a Peugeot main dealer mechanic ask me how to fix a 306 alarm system before
Posted: Wed Jul 18, 2012 6:12 am |
MrBSI wrote: |
Ash wrote: |
I have had a Peugeot main dealer mechanic ask me how to fix a 306 alarm system before |
Jesus, was he the new monkey?
Posted: Wed Jul 18, 2012 10:17 am |
LeeThr wrote: |
MrBSI wrote: |
Ash wrote: |
Jesus, was he the new monkey? |
Nope, they had run out of ideas
Blown headlamp bulb was the problem
Posted: Wed Jul 18, 2012 10:35 am |
MrBSI wrote: |
LeeThr wrote: |
MrBSI wrote: |
Ash wrote: |
Blown headlamp bulb was the problem |
How the hell did that mess about with the alarm?
