Latest: SA01
Overall: 17138
Online Now [6850]:
Visitors: 6849
Today: 570479
Total: 111884614
Forums › The Car › 206 Problems › HELP!!
HELP!!
Austin
PostPosted: Sun Jan 27, 2013 6:10 am Up
Hi guys,
Just cleaned the throttle body and MAP sensor as shown in the how-to guide on here, started car back up and it's just revving its tits off! Have checked everything is connected properly but no joy :/ Need some help please!
Austin
Austin
PostPosted: Sun Jan 27, 2013 6:42 am Up
Have just disconnected my throttle cable from body and it idles fine now :S seems the cable won't pull back through. So when I connect the cable to the throttle body it opens the butterfly slightly... Any ideas?
PostPosted: Sun Jan 27, 2013 6:53 am Up
Have you put the R clip on the throttle cable back in the right place? When it's on, there should be a bit of slack in the cable.
Austin
PostPosted: Sun Jan 27, 2013 4:11 pm Up
It's all sorted now, for some strange reason the throttle cable would not pull back through enough. Tried to connect again and it was fine :S thanks for reply though macca
