Latest: heikkisj
Overall: 17126
Online Now [46]:
Visitors: 45
Today: 19700
Total: 100329039
Forums › The Car › 206 Problems › Wobble come from front wheels
RoweY
PostPosted: Tue Feb 05, 2013 6:04 am Up
My wheels seem to wobble a lot when driving, I think it could have something to do with the suspension as they wobble up and down not side to side, I have had the drop link rods changed but hasn't made much difference. Any ideas ? Very Happy
Austin
PostPosted: Tue Feb 05, 2013 7:27 am Up
Get a garage to check wheels are balanced correctly, could have had a weight fall off...
Lowercase
PostPosted: Tue Feb 05, 2013 11:27 am Up
yea sounds like the balancing, if it only does it at certain speeds then thats the culprit.
RoweY
PostPosted: Tue Feb 05, 2013 11:54 am Up
no it does it after going over bumps in the road ? I had my wheels checked last week when i was getting the drop link rods changed.
PostPosted: Tue Feb 05, 2013 1:00 pm Up
How do you know they wobble up and down. Are you hearing a thumping noise or have you somehow seen it?
RoweY
PostPosted: Thu Feb 07, 2013 3:19 pm Up
Yes hearing a thumping sound!
P6RAF
PostPosted: Thu Feb 07, 2013 3:27 pm Up
Could be a couple of things but to be honest the only real way to solve it would be to jack it up and start pulling, pushing and shaking the wheels till you find which part is moving that shouldn't be. Be careful with the jack though obviously.
I'm guessing it may be either track rod end or wish bone bush. But you or someone will need to take a closer look at what's going on.
Although I'm surprised who ever change your drop links didn't have a look around whilst changing it.
2004 206 HDi GTi, Obsidian Black.
VW Polo 1.3 GL - 205 GTI 1.6 - 306 D-Turbo - First 205 GTI 1.9 track car - Second 205 GTI 1.9 Track car - 106 XLD - Impreza WRX - 406 V6 - 206 HDi GTi
RoweY
PostPosted: Thu Feb 07, 2013 3:29 pm Up
I changed my own drop links myself and didn't see anything when i was checking it out i might try new wishbone and see if that solves it Very Happy cheers!
P6RAF
PostPosted: Thu Feb 07, 2013 3:33 pm Up
They ain't that cheap buddy. I would seriously recommend looking closer at the problem. I would want to be responsible for suggesting you replace the wishbone without confirming it first.
RoweY
PostPosted: Thu Feb 07, 2013 3:39 pm Up
I'll have a closer look tomorrow on my day off, thanks for the advice Very Happy
P6RAF
PostPosted: Thu Feb 07, 2013 3:43 pm Up
You may need a long bar to help force the wishbone up and down to look for any play.
Good luck
PostPosted: Fri Feb 08, 2013 11:52 am Up
Also check antiroll bar mounting rubbers for play.
Is the clunking an exhaust knock against the floor?
Broken spring?
Knackered damper?
Engine mounts even?
Loose radiator?
Loose battery?
RoweY
PostPosted: Fri Feb 15, 2013 11:15 am Up
I sorted this by changing the front wishbones Very Happy
