Posted: Tue Feb 19, 2013 4:28 am |
Could anyone take a picture of the wires under both front seats on there 206 GTI please for the air bags? Need to re wire mine up.
Cheers
Posted: Tue Feb 19, 2013 7:01 am |
arent the GTI seats also heated seats?
Posted: Tue Feb 19, 2013 8:13 am |
Simmo wrote: |
arent the GTI seats also heated seats? |
I wish but no.
Posted: Tue Feb 19, 2013 10:18 am |
Some one please help
Posted: Tue Feb 19, 2013 10:53 am |
A picture would probably be of no help since Peugeot don't do things the easy way.
They use wire numbers rather than colours.
Are you after connecting using the original connectors or just joining the wires?
Posted: Tue Feb 19, 2013 11:42 am |
Zack wrote: |
Cheers |
Non plexed OR multiplexed 206 & / or seat airbags as there wired DIFFERENT
Posted: Wed Feb 20, 2013 2:45 pm |
Posted: Thu Feb 21, 2013 3:52 am |
Help please
Posted: Thu Feb 21, 2013 4:32 am |
I don't actually understand what you are asking for.
It looks like the wires are already connected using a connection block (not recommended).
Is it the connection at the bottom you are trying to sort, and work out where it connects to?
Posted: Thu Feb 21, 2013 4:46 am |
macca1411 wrote: |
Is it the connection at the bottom you are trying to sort, and work out where it connects to? |
What would you use to connect them?
That connects under the seat but the air bag light stays on does my head in.
cheers
Posted: Thu Feb 21, 2013 4:52 am |
Solder and heat shrink sleeving to connect wires, terminal blocks are too hit and miss, especially for something like airbags..
The airbag light might be on for another reason. The only way to find out what's causing the light is to plug the car into PP2000 and get the fault on the airbag ECU read.
Posted: Thu Feb 21, 2013 5:21 am |
Ill do that once i no the wires are the right way.
Check every where else all wires are good but yea would be good to get a read on it.
the PP2000 is a gun ha i googled it.
You no any one with a reader?
cheers
Posted: Thu Feb 21, 2013 6:27 am |
I don't know if any one near you has PP2000 (Peugeot Planet 2000)
There are plenty of people with the lead and software now, so could be one near you. Just post up a thread asking if anyone has PP in the .......area.
Posted: Thu Feb 21, 2013 9:10 am |
Would the air bag go off on its own?
cheers
Posted: Thu Feb 21, 2013 10:11 am |
The airbag light will stay on / flashing until the fault is fixed.
