Latest: ArtistKS
Overall: 17145
Online Now [102]:
Visitors: 101
Today: 18494
Total: 115891557
Forums › The Car › 206 Problems › coolant amount
coolant amount
saiefovech
PostPosted: Fri Jul 05, 2013 1:56 pm Up
Hey Folks ,
Iam planning to change the timing belt / water pump for my 206 1.4 8v 75HP manual.
i would like to ask about how many liters of coolant i will need to buy in order to re fill it as i will buy the ready mixed coolant.
Your assistance is much appreciated ,
Cheers
PostPosted: Fri Jul 05, 2013 2:09 pm Up
Buy neat and buy 3 litres of coolant
saiefovech
PostPosted: Fri Jul 05, 2013 10:55 pm Up
Thank you..
If I understand ill need to get 4ltrs ?
PostPosted: Sat Jul 06, 2013 2:02 am Up
No, buy a 5 litre bottle and use three. Then top the rest up with water
PostPosted: Sun Jul 07, 2013 4:41 am Up
+1
If you buy neat antifreeze (100%) you then have to dilute with 50% water.
(It then has maximum heat efficiency the way they've composed it).
I always use de-ionised water for this or topping-up, if needed.
OR you could get ready-mixed stuff, so-called 50/50 but make sure it's OAT in any case.
Capacity should be 5 litres or 7 litres depending on radiator fitted.
