Latest: sparrowdclxvi
Overall: 17139
Online Now [534]:
Visitors: 533
Today: 103450
Total: 112787348
Forums › The Car › 206 Talk › GTI 180 Gearboxes
GTI 180 Gearboxes
iainlovatt
PostPosted: Tue Oct 29, 2013 10:17 am Up
Can anyone confirm that the 180 Gearboxes are Interchangeable. i.e. they have not changed in design and a late 2003 gearbox will fit a 2004 gti 180.
Cheers
(My Garage)
PostPosted: Tue Oct 29, 2013 1:25 pm Up
Yeah they are fine. All the mounting holes are the same.
Indigo_GTI
PostPosted: Wed Oct 30, 2013 7:36 am Up
there's another thread on this from recently, as i thought they were interchangeable, but that said not? worth a check
dicko79
PostPosted: Thu Oct 31, 2013 6:55 am Up
Some have 2 fixing points for the mounting bracket and some have 3 fixing points so you need to check what yours is
Maybury180
PostPosted: Thu Oct 31, 2013 2:32 pm Up
It depends on the code on the gearbox recently had to change mine recently and I could only use a 20DM77 or 20DM78 as I found out the hard way as I bought 2 other gearboxes both off 180's however the sensors and gear selector were different to my box, even swapping the sensors over and gear selector to fit these gearboxes still wouldn't work
