Latest: sparrowdclxvi
Overall: 17139
Online Now [113]:
Visitors: 112
Today: 14686
Total: 113427386
Forums › The Car › 206 Problems › 206 gti 180 Bleed Pionts?
gd_85
PostPosted: Tue Nov 19, 2013 12:08 pm Up
Hi,
I am wanting to change the coolent on my gti 180 but not sure where all the bleeding pionts are? Main reason for changing the coolent is the car seems to warm up really fast and runs at about 90 and raises almost staight away in traffic.
Cheers.
DanT
PostPosted: Tue Nov 19, 2013 12:46 pm Up
They run at about 90 normally, and due to the design of the cooling system it does raise quite quickly when sat still or slow moving, and then back down to 90 again quite quickly too, never a bad thing to change your coolant though! One on thermostat housing and one on the heater matrix pipes on bulkhead iirc, cant remember if there was one on the rad itself on the 206. (Other frenchness stuck in my head haha)
gd_85
PostPosted: Sun Nov 24, 2013 2:17 pm Up
Thanks for the advice. Will have a look and hopefully sort it. Couldnt see one on the rad know there was one the 106.
PostPosted: Sun Nov 24, 2013 2:50 pm Up
Just the one on the thermostat housing and heater hoses. Radiator bleeds itself through the top hose into the coolant reservoir!
DanT
PostPosted: Sun Nov 24, 2013 6:05 pm Up
Could be where i remembered it from haha. Knew the other two were definite though, hope all is sorted now.
gd_85
PostPosted: Thu Nov 28, 2013 12:55 pm Up
Yep spotted them now, cheers. yea much happier with it done.
