Online Now [407]:
Visitors: 406
Today: 124874
Total: 128342298
Forums › The Car › 206 Problems › Radio Signal
Radio Signal
RockRulz
PostPosted: Sun Dec 22, 2013 1:01 pm Up
Does anyone else have a s**te signal from the FM stations.
I know its the car aerial because my 607 was fine at picking up signal but my 206 is pants. Ive tried all different stations and its the same......drifting in and out....I now play CDs most of the time but I like to do the quiz on my local station (Heart) in the mornings. Should I/Can I get an independent aerial or is the one Ive got fixable....its gotta be that hasnt it??
www.facebook.com/Hazel...rington151
PostPosted: Sun Dec 22, 2013 1:39 pm Up
Well you need to check the aerial base,and the cable from the base to the headunit,I use it daily,and it's clear,it's fixable for sure
RockRulz
PostPosted: Sun Dec 22, 2013 1:40 pm Up
I'm no electrician though...I wouldnt know where to start?
PostPosted: Sun Dec 22, 2013 1:51 pm Up
I can guide u if you like,you need to start by make sure the aerial is tight,the long section,if it's tight,then we need to move inside,and you need to take off the interior light off,so you can see the aerial base inside,and make sure it's not lose,can you do this so far?
RockRulz
PostPosted: Sun Dec 22, 2013 2:01 pm Up
I will check it tomorrow as its dark now. I did try and wiggle the aerial today and its tight so I am gonna assume its an inside problem.
PostPosted: Sun Dec 22, 2013 4:02 pm Up
Original Peugeot radio? Some cheap after market radios are pants at FM reception.
PostPosted: Sun Dec 22, 2013 4:26 pm Up
Keep us posted,and it can be solved for sure Smile
commandosqueak
PostPosted: Sun Dec 22, 2013 6:16 pm Up
what radio have you got?
2003 206 1.4 HDi (3 Door) LX - Cypress Green - KQM
2003 206 SW 2.0 HDI Grey
mjsroofing
PostPosted: Sun Dec 22, 2013 7:13 pm Up
Do a simple test for me, put radio on , while listening to it turn on your rear screen heater/demister.
Does this make the signal worse.?
Do you use the rear screen heater often.?
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
DSWR
PostPosted: Sun Dec 22, 2013 8:48 pm Up
I've always had good signal in my pug. It's not full bars, but it's been 2 or 3 most of the time. (my headunit displays signal bars like a phone)
GTi 180 owner!:)
www.facebook.com/notdanwhite
RockRulz
PostPosted: Mon Dec 23, 2013 6:29 pm Up
Original radio. No I have never used the demister as yet.....well only once to check it worked. Went for a drive earlier and went through all preset stations.....all were drifting in and out but some were worse than others.
mjsroofing
PostPosted: Tue Dec 24, 2013 3:19 am Up
Did you try turning your demister on while you had radio on.??
Mark
RockRulz
PostPosted: Tue Dec 24, 2013 3:25 am Up
No because I hadn't read those comments til
after I'd been for a drive. I will be going out tomorrow for
sure but not too sure about today. I will try the demister
as soon as I can and let you know the result.
RockRulz
PostPosted: Tue Dec 31, 2013 2:57 am Up
Ok...so Ive tried turning the demister and other bits on and off...most dont have any effect but the demister does make the signal worse. Yesterday was horrendous....every radio station was just static all the time...unlistenable at times. Ivew done myself a couple of CDs to out in there because I can see myself getting a hammer to it soon. grr!!
HAPPY NEW YEAR TO YOU
mjsroofing
PostPosted: Tue Dec 31, 2013 3:44 am Up
If the demister makes it a lot worse you might have a alternator issue which you would have to get checked out.
Some cars have powerfull amplifiers built in and take a lot of power, if the alternator voltage is droppping it can effect the amplifier, putting the demister on shows this up as that also takes up a lot of power.
Mark
