Posted: Thu Apr 03, 2014 6:44 am |
2005 1.6 HDI GTI
For the last 3 days my blower has been stuck on cold. It says 28degrees but definitely is not. I've had this issue before, but its been remedied by having the engine turned off for a few hours.
Now, its still on 3 days later.
My engine temperature is a constant 75ish and 90 when sitting in traffic then drops down again.
Is this a heater issue?
I've had no over heating issues either.
Any advice?
Posted: Thu Apr 03, 2014 2:45 pm |
Sounds like you need to change your thermostat.
Posted: Fri Apr 04, 2014 2:51 am |
It's working again now.
Checked coolant level and that was the same as it was when I changed the radiator on Xmas day.
Posted: Fri Apr 04, 2014 6:24 am |
Your engine temperature is running to low though. Should run at a constant 90. Up to 95 before fans kick in.
Posted: Fri Apr 04, 2014 9:07 am |
Thanks Steve, I'll look into it.
