Latest: Mr-Koekwaus
Overall: 17125
Online Now [159]:
Visitors: 158
Today: 2864
Total: 99362631
Forums › The Car › 206 Problems › My 206 2001 Model Clock Display IS Dim, Why?
byronwells
PostPosted: Tue Apr 08, 2014 12:16 pm Up
Alright guys
This morning I notice that my clock display on my Peugeot 206 2001 was very faint , could hardly see the time at all in daylight and now it has completely died on me..
I got told that it was the bulbs in it going.. But I have just taken the clock display out the car and looking at I can't see any bulbs in it..
RichardEke
PostPosted: Tue Apr 08, 2014 12:54 pm Up
Hello there,
I had this happen, the display went really faint and because there was no light coming from behind it you couldn't see it at all in the dark.
Here's a picture of the back of the display and the 3 bulbs twist out.
FYI: £1.50 for 3 new bulbs from Peugeot. For that price i replaced all 3 instead of going through trying to find out which individual one it was.
Hope that helped.
Regards, Richard.
PostPosted: Tue Apr 08, 2014 12:55 pm Up
There are backlight bulbs that are held in by bulb holders that twist then pull out.
Being a 2001 model I would guess it's non plexed as the clock displays on these the solder joints can break inside cutting of the power to the backlight bulbs.
byronwells
PostPosted: Tue Apr 08, 2014 1:00 pm Up
RichardEke wrote:
Hello there,
Hope that helped.
Regards, Richard.
I have different display clock than the picture you have showed me.. I got a 2001 hatchback model..... I've got one similar to this one www.ebay.co.uk/itm/191...1423.l2649
PostPosted: Tue Apr 08, 2014 1:07 pm Up
The white bit in middle is the bulb holder, twist it & it should release.
byronwells
PostPosted: Tue Apr 08, 2014 1:13 pm Up
Thanks for that.. So I should now be able to get a blue bulb for that Smile
PostPosted: Tue Apr 08, 2014 1:30 pm Up
You can BUT it's not that simple to change the colour Wink
There is an orange filter inside the display that makes the colour, the normal bulb is clear.
byronwells
PostPosted: Tue Apr 08, 2014 2:56 pm Up
Oh darn lol
gazza82
PostPosted: Wed Apr 09, 2014 4:38 am Up
There are two types: one basic one and one with extra lines for temp etc. And there are two systems ... which means there are FOUR MFDs around! Some had three bulbs, some have four.
Pre-plex and mux/plex don't mix!
PostPosted: Wed Apr 09, 2014 11:19 am Up
OP has got the bog standard poverty spec CLOCK with 1 backlight bulb, its not an MFD on OP's car.
Also there are a lot more then 4 MFD's Wink
