Forums › Tuning, Modification & Legal › Project Cars › Macs rally 206 project..latest rolling road results 200+hp |
Posted: Mon Apr 21, 2014 11:47 am |
220lb ft??? from a N/A 2 litre engine?
Posted: Mon Apr 21, 2014 12:42 pm |
Edward wrote: |
220Nm??? from a N/A 2 litre engine? |
I cant wait to see the figures..... Charlie is fairly confident he can get it
Posted: Mon Apr 21, 2014 2:14 pm |
Even to get over 90lb ft per litre is doing extremely well so 110lb ft per litre...you'd need a miracle!
Posted: Sun May 25, 2014 2:12 pm |
Bit of an update on engine progress.
So far the crank is finished, fully knife edged and a load of weight gone.
Billet steel flywheel purchased from Pug1off
Billet alloy crank pulley from Pug1off
Custom Cams from Piper with an approx 288 profile made for us by the man himself
Cylinder head further modified with 2mm bigger inlet and exhaust valves. The biggest issue here is the cams have too bigger lift for the springs. The solution is to fit custom springs and machine the spring seats to fit. The decision to fit hydraulic lifters has been suggested by Piper themselves as there may be issues with fitting solids.
Dummy build was being done last week to see if the pockets were big enough in the pistons.
Next step is to do the machining and final build, set up the cams and refit the engine in the car if everything fits. Weld up the engine mounting points and send it off to the rolling road....... all before FCS
Posted: Sun May 25, 2014 3:49 pm |
sounding good and expensive lol, glad its coming together
Posted: Sat May 31, 2014 12:45 pm |
Posted: Sat May 31, 2014 12:48 pm |
Schumi wrote: |
Be careful with oil pump. It can be explode at 9000 rpm. Lots of French guys know this problem. My GTI180 Turbo friend lost oil pump 2 times. |
An update for you Schumi.... I have found a manufacturer of an upgraded oil pump for the EW10J4 and S engines........ wider rotor and made of stronger stuff..... I have one fitted in my new engine and have another pump coming.....
Posted: Wed Jun 04, 2014 2:01 pm |
macj wrote: |
Schumi wrote: |
An update for you Schumi.... I have found a manufacturer of an upgraded oil pump for the EW10J4 and S engines........ wider rotor and made of stronger stuff..... I have one fitted in my new engine and have another pump coming..... |
Would you mind saying where from and cost as maybe interested in a pump
Posted: Wed Jun 04, 2014 3:06 pm |
AWK-53 wrote: |
macj wrote: |
Schumi wrote: |
Would you mind saying where from and cost as maybe interested in a pump |
I will post up all details when the other pump arrives with me. I will photograph it and provide spec. I will have an accurate price when I have an idea of quantity order
Posted: Wed Jun 04, 2014 4:48 pm |
macj wrote: |
Schumi wrote: |
Is that company from France and name contains rally ? Dont complete name if you know.
| 2005 206 RC RED
Lot's of CNC machined customs pars. | |
Posted: Thu Jun 05, 2014 8:22 am |
UPDATE from roller session. timing Belt came off at 4000 rpm and am waiting on outcome...... dont hold out much hope of a good outcome
Posted: Thu Jun 05, 2014 10:36 am |
bad times hope its not a full rebuild
Posted: Thu Jun 05, 2014 11:27 am |
Posted: Thu Jun 05, 2014 11:49 am |
Sorry to hear that
Posted: Thu Jun 05, 2014 12:18 pm |
Oops. Sympathies. That flywheel is too nice the be hidden in a bell housing.
