Latest: Mr-Koekwaus
Overall: 17125
Online Now [64]:
Visitors: 63
Today: 25320
Total: 99385001
Forums › The Car › 206 Problems › Peugeot 2.0 HDi Not Starting
SebJ
PostPosted: Tue Apr 07, 2015 11:06 am Up
Hi,
I've owned my Pug since May last year, and its been running fine since then, last Thursday I parked it up (had been running absolutely fine), and left it until the Sunday when i tried to start it up again it wouldn't start!
If you turn the key you can hear it trying to go but it just wont start.
I had the breakdown out, they said it could either be the immobiliser or the injectors. Apparently fuel is going through, but it just isn't starting up...
A neighbour had a code reader and it gave out the following codes: P1352, U0028, P0092, U1003. Whether these have got anything to do with it not starting I don't know...
At the moment, it's in a garage and the mechanic has said I need the ECU to be removed and sent for testing, not sure about this!
Has anybody had anything similar happen? Im a bit lost, and dreading some big bills!
Thanks for your time.
Hawkers
PostPosted: Tue Apr 07, 2015 1:41 pm Up
Have you checked the battery? When it doesn't start do you hear a rapid ticking sound upon turning the key?
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
SebJ
PostPosted: Tue Apr 07, 2015 2:09 pm Up
The battery is fine, and no there's no rapid ticking sound, like you turn the key and it makes the kind of normal turning over sound, but doesn't start...
Hawkers
PostPosted: Tue Apr 07, 2015 2:22 pm Up
Fault code: P1352
After sales description of the fault code: Engine preheating : Fault on the pre-heating relay or glow plugs
Have you checked your glow plugs?
SebJ
PostPosted: Tue Apr 07, 2015 3:18 pm Up
I wouldn't know how to (diesel newbie here...), I'll get the garage to have a look tomorrow!
