Posted: Sat Jun 18, 2016 7:33 pm |
Hi I was wondering I have a 1.4 8v tu3a engine and was wondering if they have hydraulic tappets? If not how do I stop tapping noise?
Posted: Sat Jun 18, 2016 7:52 pm |
No hydraulic tappets on a TU3.
There manual adjustment & must be set COLD - engine left standing overnight to cool down.
Number 1 cylinder is gearbox end.
You need a new rocker cover gasket & don't over tighten the rocker cover bolts as you will warp the cover leading to leaks.
FWIW: The stoneage mid 1980s TU engine design has always been a bit tappy.
Posted: Sat Jun 18, 2016 7:56 pm |
I not too confident in doing this roughly do you know how much it would cost for a garage to do it
Posted: Sat Jun 18, 2016 8:01 pm |
I would suspect an hours labour charge would cover it.
It would be a simple job for an older mechanic to do.
Posted: Sat Jun 18, 2016 8:08 pm |
Ok thanks will speak to my garage bloke on Monday.
Posted: Tue Jun 21, 2016 2:20 pm |
The inlet valve lifters were loose
Posted: Sun Jul 10, 2016 8:45 pm |
What did they charge? What parts used?
