Posted: Fri Aug 12, 2016 9:34 am |
Okay abit of background. Have a 1.6 hdi 110
When bought it came. With engine lightt and anti pollution and dpf warnings... Car was limping... One fault remained (fuel cap sensor), mechanic said not to worry just leave it
Got dpf removed and mapped out, soon after the car started missing on cold starts and woul stop once warm
Got the glow plugs changed and turbo as impeller was chipped but was performing fine
Soon after this i noticed car noticeably slower from 2-3000 revs and it was missing like crazy one time through all gears throwong white smoke out... Took this to another mechwnic to look at injectors and the car was driving fine again but loss of power still there... Got told injectors are fine but new codes: throttle valve sensor and egr... I need some help here as im boggled as to what the cause of this is or is it linked to any work carried out on it???
Posted: Fri Aug 12, 2016 10:15 am |
DV6 engine = biggest pile of s**te PSA Peugeot / Citroen has ever produced.
One that's been fiddled with will be even worse.
Posted: Sat Oct 01, 2016 2:14 pm |
Update: for anyone interested or has a similar problem..
Took the car to a place i know, which i shouldve done in the beginning
Within 10 minutes he found out the mapping from the dpf removal was the cause. Turns out the dpf was only removed from the codes so the car still thought it had one causing all these problems
Missing at idle and bunny hopping has stopped and 90% of the power is also back just one injector needing a repair to get it back to normal.
I would not reccomend OMG Performance in Slough as this is the person who did the bodge job and was sending files to and fro poland before putting them into the car!
On the other hand, i cant reccomend Mark at South west incar tech enough, i had been to him for a remap on my previous car and wish i did my dpf removal from there in the first place.
Posted: Sat Oct 01, 2016 7:34 pm |
only ever use Hd-Tuning for my car. both stage 1 and stage 2. Will soon be going through the process of stage 2+/3ish...
