Forums › The Car › 206 Problems › bottom radiator hose clip gti 180 |
Posted: Tue Apr 18, 2017 10:20 am |
i have removed the clip on the bottom hose of radiator and have pulled but the swine wont come off.. is there a special way to remove this pipe ?
thanks
Posted: Tue Apr 18, 2017 10:53 am |
Get a screwdriver under the hose slightly. It will have glued itself on over the years.
Posted: Tue Apr 18, 2017 7:05 pm |
i just bought a second hand one off ebay cheap. its having new radiator so cba messing about haha.. never known anything like it i was pulling at it for ages lol
