Posted: Mon Jun 26, 2017 7:36 am |
Hi all. Having one problem after another at the moment, as soon as I fix one I get another! new coil pack, exhaust then rear suspension, each problem one after another!
I now have a rattle that I can't tell where it's coming from. All I know is it's a rattle that is constant, and increases in speed (mph not engine speed)
It disappears on occasion when accelerating, but disappears completely when braking, as soon as I lift off the brakes it starts again.
Please can someone give me some pointers, don't think I can afford to go back to the garage yet.
Many thanks,
Dan
Posted: Mon Jun 26, 2017 10:28 am |
Wild guess something to do with ya brakes ???
Could be the pads not returning into the calipers ??
I'm sure someone else will be along shortly with a better idea ! Lol
| 206 1.1 independence 54 plate, 3 door
(West Yorkshire) | |
Posted: Mon Jun 26, 2017 12:09 pm |
Took it out again and can tell its coming more from the left and possibly front so could well be the brakes. (I hope so)
Posted: Mon Jun 26, 2017 1:50 pm |
I get the brakepads squeak when not braking (regardless acceleration or not), as soon as the brakes warmup (few minutes into driving)
Sometimes there is also a thunking noise, once every wheel's revolution. (is your rattle sounding like a caliper against alloy spokes)?
Have you changed your brake pads+discs recently, so the caliper maybe sitting out by a bit too far?
Doublecheck your wheel bolts are tight and there is no play in the suspension, as well as have you got any aftermarket alloys with a too-tight offset?
Posted: Tue Jun 27, 2017 7:52 am |
Changed the front brake pads last night and the rattle has gone, thanks guys!!!
Posted: Tue Jun 27, 2017 6:17 pm |
