Posted: Tue Aug 08, 2017 1:01 pm |
I have a 2005 1.4 8v S 206 and every week or so the clutch falls to the floor until I give it a stamp then it comes back up.
I have read this is the Auto adjuster on the clutch, however I took it to a garage and they have said there is no auto adjuster and they recon I need a new clutch.
So I was wondering if this could be the case?
Posted: Tue Aug 08, 2017 2:18 pm |
Should be an auto adjusting cable for your clutch.
What can happen is the fingers on the pressure plate can fail & this can cause the clutch pedal to fall to the floor.
Posted: Wed Aug 09, 2017 6:25 am |
Thanks for your reply. The garage said they thought something might be getting stuck on the cone (I don't know what this means) and when I give the pedal a stomp its unjamming.
When the pedal goes to the floor I can push it maybe an inch and this varies it from say 60% bitten to 40% bitten (as it would be higher in the travel when its working fine).
Do you think that would sound more like the cable or the clutch?
Posted: Wed Aug 09, 2017 3:17 pm |
You could try a replacement clutch cable BUT I would think your gonna end up fitting a new 3 part clutch kit, clutch cable & gearbox input shaft sleeve.
Posted: Tue Aug 15, 2017 6:25 am |
Have had the clutch cable replaced and the grinding feeling of pressing the clutch has gone away, feel as good as when I got it now.
Time will tell if the pedal flops again but I'm feeling positive. The car has only done 35k so would be a bit upset if clutch had gone already.
Posted: Tue Aug 15, 2017 8:43 am |
rhx1 wrote: |
The car has only done 35k so would be a bit upset if clutch had gone already. |
Its 12 years old.
It could have spent its life in stop / start city traffic.
It could have be driven be someone that likes to sits stationery in traffic with the car in gear with there foot holding the clutch down.
Posted: Thu Sep 14, 2017 7:31 am |
Just an update on this, had no issues since replacing the cable.
Car feels as good as when I got it.
Posted: Thu Sep 14, 2017 12:34 pm |
Cable was probably starting to part inside the cover and getting jammed. Wouldn't have been long before a good stamp would have finished it off and you had no clutch ....
