Posted: Fri Sep 29, 2017 8:06 pm |
Hi all
I’m back with another 206 gti and I’m pleased with it, though I’m trying to get to the bottom of a few issues I’d like some help with please.
1) auto lights won’t activate.
I’ve tried everything, pressing everything I can find to turn them on but they won’t. When changing the bulbs I found a plug loose at the back of the lights but putting it back in changed nothing.
2) movement in bottom engine mount
Not sure how much movement is acceptible but when underneath I can move the engine with one hand an amount that I don’t think is correct. Has anyone fitted the super flex bush insert to the standard bush?
3) remote locking doesn’t work via key
I’ve tried everything I’ve found on here to reset or resync the key to the car but nothing. The strange thing is there is no flashing light on the dash as I would expect, but there is the switch to turn off the sensors.
Sorry for rambling on but any help would be most appreciated.
| 206 gt - gone (sadly)
206 gti 2003 - Sahara yellow - gone
206 gti 2002 - silver - present car!! | |
Posted: Sat Sep 30, 2017 12:38 pm |
Can anyone help with anything please?
Posted: Fri Dec 08, 2017 5:13 am |
ive the powerflex bush on mine and its a great item, ive found with mine on the key its doesn't deactivate the alarm , that's push button only.
your lights I cant help on that sorry
also check the gear box mount as I found mine had split causing a fair bit of movement
| sanity in an insane world is insane
4 wheels move the body 2 wheels move the soul | |
