Forums › The Car › 206 Problems › GTi 180 annoying noise |
Posted: Thu Jan 18, 2018 8:20 pm |
Hi everybody! Anyone experienced a rattle noise from the plastic cover of the timing belt? Mine always did it, I actually located the noise and I would like to fix it...
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Fri Jan 19, 2018 4:25 pm |
Are all 3 or 4 bolts in properly?
Posted: Fri Jan 19, 2018 4:49 pm |
In my case those were the exhaust manifold heat shield nuts that'd come undone, rattle at a specific RPM.
Posted: Fri Jan 19, 2018 8:33 pm |
I just changed cambelt, it did it before and after, so I assume yes...
I already fixed manifold heat shield, that's now silent.
The noise I get comes surely around cambelt, in particular with cold engine, around 1800 rpm.
