Forums › The Car › 206 Problems › Remote Central Locking issue, help needed |
Posted: Sat Jul 07, 2018 4:24 pm |
Hi,
First post so please don’t judge
I bought a 206 1.4hdi 2005 (55) 3 door for my lad for his first car
Great little car just want he needs.
I bought the car from what I thought was a repetuable garage in Wiltshire
So basically the car has been messed about with ( by this garage I believe )
It came with two keys, one for the ignition the second for the rest of the car, he said the ignition barrel failed and had to be replaced ( fair enough these thing happen ), also said the remote battery was probably flat ( stupidily I didn’t question this )
So we accepted the car and drive the 50miles home, lad loves the car so he wants to sort it.
I phone the garage to say the remote battery was not the problem ( as I’ve changed it ) re-visited the garage and he says the remote board I’d fubar too and needs replacement ( which he says is not covered by the warranty)
So lost it and drove home, I found a local key/electrician who buys and fixes broken keys on the road side, he said he’d be able to fix it, just needed to order the remote ( I asked for two ). The next week he returned to fit and this is when the problems came to light.
The BSI has been changed ( know this as the VIN was different to the car ) b******s. He managed to change the VIN to the original, code the Two new transponders to the car ( now have 3 working transponders) but the remote refuses to work, after 3 hours the guy gave up.
Can anyone help out with a solution if there is one please
Cheers
Posted: Sat Jul 07, 2018 9:12 pm |
Hello and welcome,
Try to resync the key with the BSI: turn ignition on, press and hold the big (lock) button for 10 seconds, release, then switch off ignition, close doors, try to lock and unlock the car.
Posted: Sun Jul 08, 2018 3:41 am |
Sim wrote: |
Hello and welcome,
Try to resync the key with the BSI: turn ignition on, press and hold the big (lock) button for 10 seconds, release, then switch off ignition, close doors, try to lock and unlock the car. |
Hi Sim,
Yes tried this on all three remotes, no joy
Posted: Mon Jul 09, 2018 5:17 am |
Are there any clues as to what was used to code the new keys to the car?
Posted: Mon Jul 09, 2018 8:17 pm |
VorTechS wrote: |
Are there any clues as to what was used to code the new keys to the car? |
Just messaged him and got the reply of,
Peugeot Planet & X100 Key Programmer
