Forums › The Car › 206 Problems › Hatchback 2A/C 1.6l Belt problem. |
Posted: Fri Nov 23, 2018 5:07 am |
Posted: Fri Nov 23, 2018 7:46 pm |
Hello there TU5JP4 friend,
Autodata gives this routing for your full fat setup (I can't look up on mines as it currently has electronic PAS conversion):
This is the tensioner layout and part numbers for your 1.6 16v (you can see the length of the belt is 1560mm):
Good luck with the squealy pig problem and keep us posted!
Posted: Sat Nov 24, 2018 3:43 am |
Wow! Sim thank you sooo much!
You have helped me enormously, I think who ever had fixed this car previously had followed a lot of other 3rd part sites and parts distributors, which list the 1575mm belt!
Replaced the idler pulley and tensioner assembly - new belt at 1560mm!
No longer a squealy pig, but purring lion!
I will get myself organised will pics and details now I know about this forum
Again thank you for your help
