In order to utilise PP2000 to its maximum (e.g. recoding keys), I need to be able to extract the BSI pin from my Pugs. I've downloaded a couple of PSA calculators & ECU dump progs but the two USB-OBD2 cables I have (one is Lexia3) aren't recognised.
Does anyone have/know of a correct USB-OBD2 cable which works with any PIN calculator/decoded software please?
Thanks.
Posted: Sat Sep 07, 2019 12:01 pm
You can't extract a PIN with USB/OBDII - ECU and BSI needs to be benched.
Posted: Sun Sep 08, 2019 8:55 am
A great blast from the past, good to see you on here again
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
