Latest: jeromequi
Overall: 17111
Online Now [211]:
Visitors: 210
Today: 2971
Total: 93654952
Forums › The Car › 206 Problems › Aftermarket head unit wiring.
Darbleberry
PostPosted: Thu Jun 18, 2020 12:57 pm Up
Hi all,
After some advise.
I'm planning on installing a aftermarket heat unit but need a suitable fuse to piggy back off so it turns on and off with the ignition.
is there a preferable fuse to use or can any fuse be used as long as it becomes live with the ignition.
sorry for the simple question.
gazza82
PostPosted: Thu Jun 18, 2020 9:15 pm Up
Just use the correct wiring adaptors ... the Sony we put in one of ours was a doddle to install and all i needed to do was swap the red & yellow feeds to maintain the memory.
Meant when we sold the car we kept the radio and moved it to another make ..
ekjdm14
PostPosted: Thu Jun 18, 2020 9:22 pm Up
Agreed, chopped in radio can also cause other issues with the MFD (Clock/outside temp etc) not working.
+'99 306 2.0SE cabriolet
+'97 306 1.9LXDT
French Car Forums
PostPosted: Sat Jun 20, 2020 8:05 am Up
There is a wiring loom and connector meant for the stereo (headunit) behind where its fitted and they're saying it's better to use that, with an appropriate adapter for the specific brand stereo you are fitting. It includes properly fused and rated permanent live (for memory presets, clock etc.) and switched aka 'ACC' (accessory).
The adapters are very cheap and can be bought on-line, make sure you get the right one though. Smile
