Forums › The Car › 206 Problems › 206 GTI 180 2003 - No heating |
Posted: Mon Oct 19, 2020 1:34 pm |
Hello Fellow Pug owners!
I'm new here so please bear with me.
I have recently bought 206 Gti 180 at (what I thought) a bargain price.
Driving home I've discovered there's no heating (yes it does have digital climate control) - all the controls seem to be working fine - fan speed, temperature control, climate control, variable fan speed when changing the temperature on "auto".
So far, this is where I got to:
- I've changed the heater matrix
- Blower works fine on all speeds
- I've bled the coolant system (about 8127 times, just in case)
I've also had the car checked out by a local garage - so it's nothing obvious or super bad (like head gasket).
Things I've not yet looked at:
heater motor actuator - where is it located? How to get to it?
Heater resistor? - I'm not sure what it does exactly
What else can I look at myself before giving it away to a specialist (Cheaper I've found so far is £45 for first 30 minutes, already telling me that based on above description he'd have to strip the whole dashboard [i.e. EXPENSIVE])
Please let me know if anyone had similar problems, or shout any advice you may have!
Thanks!
Posted: Mon Oct 19, 2020 7:44 pm |
You can feel the pipe going into the heater matrix is hot?
Posted: Tue Oct 20, 2020 7:07 am |
The pipes in the engine bay going into the car are getting hot - but the plastic pipes inside going into the heater matrix are cold as ice!
