Latest: elelectricistadeMateo
Overall: 17127
Online Now [51]:
Visitors: 50
Today: 641
Total: 100398880
Forums › The Car › 206 Problems › 1.1 Starting problems
G4VHN
PostPosted: Mon Nov 22, 2010 7:41 am Up
My girlfriends 2002 1.1 has developed starting issues.
Everytime it is started it turns over more than normal before firing and when it does it runs on 3 cylinders for a few seconds.
After this it runs and drives normally. If you turn it off and start it again it starts normally.
But if left for anything more than 10 minutes it will do it again.
Its like the fuel is draining back when stood, can this happen ? Does this model have a fuel filter because i cant find it if it has.
TomMessenger
PostPosted: Mon Nov 22, 2010 7:46 am Up
Should have a fuel filter I would have thought. I'd check that and injectors, and run some injector cleaner through it
www.me-strings.co.uk - Day Job
www.tommessengerphoto.com - Occasional Job
tommessengerphoto.com/page7.htm - Fishy Stuff
G4VHN
PostPosted: Mon Nov 22, 2010 9:23 am Up
I have tried to follow fuel lines from tank to under bonnet and cant see a filter at all. There is a filter on the pick up in the tank, under back seat. I cant seem to undo the retaining ring on this to have a look though. Doesn't seem to have ever been undone and feels like its gonna break.
G4VHN
PostPosted: Wed Nov 24, 2010 4:53 pm Up
BTT
G4VHN
PostPosted: Sun Dec 12, 2010 5:14 am Up
Today on motorway car seemed to completley lose power for a split second the engine check light flashed on then went off and car continued normally.
When is checked code was shown as P0461 Fuel level sensor ????
Would this cause my problems
