Latest: elelectricistadeMateo
Overall: 17127
Online Now [63]:
Visitors: 62
Today: 801
Total: 100399039
Forums › The Car › 206 Problems › 2.0 HDi earths???
2.0 HDi earths???
actionman
PostPosted: Wed Dec 08, 2010 12:40 pm Up
Hi
does anybody know where the earths are located on a 2001 2.0 HDi!!
Most of my lights have gone crazy & have been advised to check the earths before an auto elec comes to look at it!!
The lights that are going nuts are the brake lights & indicators!! Also the rear fog light indicator light on the dash is permenantly lit!!
Do these all use the same earth connection?
thanks
Craig Cool
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
PostPosted: Wed Dec 08, 2010 12:50 pm Up
You also checked your fuses?
panason1c
PostPosted: Wed Dec 08, 2010 1:51 pm Up
Check the earth lead from the gearbox to the chassis. A quick and easy way to confirm if its an earth fault is to connect a single jump lead fron the negative battery pole directly to the engine block and see if you still have the problem.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
actionman
PostPosted: Thu Dec 09, 2010 11:20 am Up
Sorted it!! it was the earth connection behind the side trim in the boot near the passanger side rear light cluster!! Thumbs Up
Literally i had to do was tighten a bolt up!! Wink
